Question about Splendide 2100XC
No light ,no power
No lights on front panel, dose not turn on
Powers on, then powers off, have red light, then blue lite ,then back to red light.
Do a firmware update. The fault is due to corrupted firmware. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 15, 2015 | Westinghouse Televison & Video
Left rear turn light dose not blink when clicked
remove rear left lens and install new turn signal bulb.
Feb 02, 2013 | 1998 Ford Explorer
My sanyo tv odel ce37ld33-B turns itself off and blue light flashes when i turn it back on
you have bulged capacitors on the power supply board that need to be replace in order to fix the problem
Nov 03, 2012 | Sanyo Televison & Video
My dishwasher won't start.
FIRST MAKE SURE YOU HAVE POWER TO THE DISHWASHER. IF IT HAS A LIGHTED PANEL AND ITS LIGHTED UP, YOU HAVE POWER. IF NOT LIGHTED UP WHEN TURNED ON, THEN YOU HAVE A POWER LOSS PROBLEM WITH A FUSE OR BREAKER OUT TO THE SUPPLY WIRE TO THE DISHWASHER. CHECK YOUR ELECTRICAL FUSE BOX OR FUSE THAT SAYS DISHWASHER IN THE ELECTRICAL BOX IN YOUR HOUSE. RE-SET THE BREAKER OR CHANGE THE FUSE. IF IT STILL DOSE NOT START UP THEN YOU MAY HAVE AN ELECTRICAL CONNECTION UNDER THE DISHWASHER THAT IS NOT CORRECT OR NEEDS TO BE LOOKED AT BY AN ELECTRICIAN. DO NOT TRY TO CHECK THIS AREA UNLESS YOU HAVE THE FUSE OR BREAKER OFF. THEN LOOK TO SEE IF YOU HAVE A LOOSE CONNECTION. RE-TIGHTEN THE LOSE CONNECTION FOUND, TURN ON THE FUSE OR BREAKER AGAIN, AND SEE IF THE LIGHTED PANEL LIGHTS UP. IF IT STILL DOSE NOT START UP, THEN NEXT CHECK THE DOOR TO MAKE SURE IT IS CLOSING ALL THE WAY, THERE IS A SWITCHON THE DOOR THE SENCES FULL CLOSED AND WON'T START UP IF THE SWITCH IS NOT CLOSING. IF THIS DOES NOT FIX IT THEN YOU WILL NEED TO CALL YOUR LOCAL DISHWASHER FIX IT MAN. DISHWASHER HAS A PROBLEM HE MUST FIX.
Feb 20, 2011 | KitchenAid Dishwashers
My tv power light comes on but the screen will not come on.
power light on blue , screen dose nothing ,trun off red light blinks
Apr 08, 2010 | Insignia 37" LCD Flat-Panel HDTV
Power dose not turn on
When i put plasma into power. The power light 1st turn green and suddenly goes red and does not gets on.
Mar 10, 2010 | Fujitsu Plasmavision PDS-4229 42 in....
My tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
hello sir,
please sir solve my this problem.
my tv dose not turn on , its show power light red and when I plug in its sound like timer and , then screen turn grey, I can not change any mode or volume , and can not turn it off , I have to plug it out,
Dec 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Every time i try to turn on my Gateway model MA7
  • the battery may need full charging, charge it for 4-5 hours, and it the problem persist it needs replacement.
  • for it works in power cord.
May 03, 2009 | Computers & Internet
Ford focus abs light dose not light up at all . ( 99-1.6.petrol)
read your owner manual to see when the BAS light should be on during "prove out." Sometimes the prove out is after the engine starts.
Also, if the ABS ever fails, you always still have regular power brakes.
You should go on a gravel road and slam on the brakes to se if the anti'lock still functions. You will hear the BAS motor run and the pedal pulse. good luck
Jan 21, 2009 | 2000 Ford Focus
Television Went Dead
When you first turn it on dose the LED blink? if it dose then maybe the inverter board went bad if the LED don't blink then maybe power supply
Jul 10, 2008 | TruTech PLV16320 Television
Splendide 2100XC Logo
26 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
