Question about Wildgame Innovations Video Cameras
Memory card is not recording pictures - Wildgame Innovations Video Cameras
Do i need a memory card to record..
No you do not need a memory card to record. The JVC Everio GZ-MG130 is a hard disk drive camcorder with a built-in 30 gigabyte hard drive to record to. You can, however, use an SD memory card if you want to add additional space to save your videos and pictures to.
Jul 07, 2011 | JVC Everio GZ-MG130 Camcorder
My lumix DMC-FS5 camera keeps saying "Pictures will be recorded to to built-in memory". No pictures have recorded to the memory card and I cannot retrieve pictures that have been taken and that...
In the camera menu, you will find an entry for "copy" which gives you the option to copy the internal memory to a memory card. Once that is done, remove your card, go back into the menu and find "format"...follow the on-screen instructions to erase the internal memory and promise yourself to never use it again. After that, your memory card should work properly in the camera.
Apr 13, 2011 | Panasonic Lumix DMC-FS5 Digital Camera
I have a Memory card in my camera that allows me to save still pictures to it, however, when I try to record video to the memory card it gives me the little yellow triangle and the "in Card...
I'm going to say the memory card first if you have used it before to record video then the card is corrupted and needs formatting to the camera it is being used in. Download your still pictures first then format the memory card. If this is a new card again down load pictures and format the card in the camera. The last possibility is the memory card write speed is slower then the video so no it can't write to it. Sounds confusing but really if the card was working in the camera then doesn't now then it needs to have the memory card formatted.
Jan 21, 2011 | Cameras
My camera takes pictures fine, but when I go to record a video it says it can't read the S.D card.
hi,
there are two memories on your camera. there is an on-board memory and then the memory card.
usually the on-board memory is usually small and its completely possible that you have being taking all your pictures onto the on-board memory which is not large.
because video files are usually large, it may not be possible to record your videos onto the on-board memory.
here are some tips for you.
to confirm if you have being using on-board memory for your pictures, you should remove the memory card then take pictures with the camera. if you can stiil access all your pictures then you have being using the on=board memory.
the memory card could also might have not being well inserted, so insert properly and use.
its also possible the memory card might be corrupt so scan for viruses.
or it may need formating.
N.B. before formatting please back up your data.
Jan 14, 2011 | Nikon Coolpix S4000 Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Aiptek IS DV2
Seems like its time to flush the contents of the memory card of camcorder to a computer.
There's a limited amount of memory in every memory card. After constant recording, the memory  gets full and the recorded stuff needs to be either deleted or flushed (uploaded to a computer) to make room for newly recorded stuff.
Unless you have a blank memory card, your problem should be solved by the above mentioned idea.
Oct 20, 2007 | Aiptek IS-DV2 Camcorder
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Record images
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card SHQ 2592 x 1944 3 images 69 images 139 images HQ 2592 x 1944 11 images 204 images 409 images SQ1 1600 x 1200 27 images 515 images 1030 images SQ2 640 x 480 144 images 2663 images 5324 images
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
"Recording stopped. Record in internal memory "
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Recording stopped. Record in internal memory"
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Video Cameras Logo
60 people viewed this question
Top Wildgame Innovations Video Cameras Experts
Are you a Wildgame Innovations Video Camera Expert? Answer questions, earn points and help others
