Question about Uniden DXAI4288-2 Cordless Phone
Phone not working
Haven't used the phones in about 6 mths have the dual with answering machine. Have charged and even reregistered the phone to their charges. When you push talk on the main phone you get no dial tone and it flashes talk beeps and goes away the second one comes on still have no dial tone , does the main phone have to be working? Thanks for your help
5 Suggested Answers
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
Posted on Jul 08, 2008
  • 31 Answers
SOURCE: No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Posted on Apr 16, 2009
SOURCE: When I get ready to dial, phone beeps 3 times
You must have an answering service from your phone company, and probably don't know about it. Try dialing your own # and wait for the prompts.
Posted on Aug 10, 2009
  • 160 Answers
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
  • 4 Answers
SOURCE: phone beeps before dial tone
usually this means you have voicemail...listen to the messages and delete them and the beeps should go away...
Posted on Aug 20, 2010
0 characters
1 Points
Want to increase my rings to 6 on uniden powermax5.8 ghz
Since you declined to specify the model of your Uniden 5.8GHz wireless system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Apr 26, 2012 | Uniden 5.8GHz Dual Cordless Phone
How do i retrieve messages when out of town, from my v-tech 5.8 & can i use my cell phone to do this ?
If I remember correctly you can remotely connect to your answering machine.
When you call the phone and it greets you (assuming you haven't changed the code) press 19 to get it going.
You should then begin to hear your messages. After you get past the 19 part (options are as follows)
1 ) Plays all messages 2 ) Plays only new messages 3 ) (During playback) Deletes the current message 33 ) Deletes ALL OLD messages 4 ) Repeats current message 5 ) Stop 5 ) (While no message being played) Lists Available Commands 6 ) Skips to next message 7 ) (While no message being played) Record new greeting 8 ) Hang up 0 ) Turn Answering Machine on/off
Jun 29, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
No dial tone on same used replacement phone
If I am not mistaken, you go to menu and scroll down to deregister the handset. After that, try reregistering it in the vicinity of the phone with the phone cord plug.
Aug 02, 2010 | Uniden 5.8GHz Dual Cordless Phone
One phone is not working.
The issue here in "most caases not all is the battery is at its prime" i would first buy a new battery let it charge for 20 hours!! then try reregistering the headset. if that does not work or reregister then you know now you got a bad transmitter radio inside. Try all reset methods as well even before you spend $12 bucks on a battery pack. Chances are its the battery, worse comes to worse the headset needs to be replaced.
thanks this was a FREE solution please do be considerate and rate and leave postive feedback thanks.
Apr 28, 2010 | Vtech Cordless 6041 Phone
I have a 3 phone 5.8GHz digital system. Suddenly all 3 say connecting as they sit in the charger.
I used the instructions from you to unregister and reregister each phone and they are all working again. It may have occurred because one phone was left offcradle until the battery went dead, I might need new rechargeables sometime soon...
Mar 26, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
New phone base works but extra phone doesnt
Hello, 1st step would be to make sure the phone still registered, mines keeps unregitering and it works after I reregister it, hope that helps.
Dec 03, 2008 | General Electric 28223EE2 Twin Cordless...
the phone said get register but i bon't know how to fix it
Jul 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
Doro 133R phone - answering machine not working
a bit late for this persons problem, but if anyone needs a manual here's the doro site - just type in the model number and you will be able to download the pdf....
Jan 19, 2008 | Doro 830R Cordless Phone
GE 21091GE3 - A Answering System keeps Initializing What do I do?
Is the answer off ? Theres a button above where it tells you how many messages you have that turns the machine on & off. Ive hit it by accident and then people couldnt leave messages - the machine wouldnt even pick up. HOpe this helps....
Jun 13, 2007 | GE 21091GE3 2.4GHz Dual-Handset System...
Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Jan 19, 2007 | Uniden TRU8885-2 Cordless Phone
Uniden DXAI4288-2 Cordless Phone Logo
16 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
