Question about Corel Paint Shop Pro 9
Change printers problem in Paint Shop Pro 9
Using PSP 9 with Vista home premium I cannot change printers from within the program - it will only print to the default printer. I have noted other reports of this problem but no solutions. Is there one?
  • 4 Answers
Is this stupid or what? I have the same problem. I will find the answer and report back...
Posted on Sep 23, 2009
  • mbrenengen Sep 23, 2009
    Well, sadly, there doesn't seem to be a fix for this. It is a Vista
    compatibility issue that Corel seems uninterested in fixing. And, for
    my money, even though I have been a loyal user for like 8 years, it may
    be time to move to photoshop. Here is a link to further discussion:
    http://forums.cnet.com/5208-12546_102-0....
    Scholar:
  • 65 Answers
Probably the best solution is to set your windows default printer to the one you want to use.. then when/if you print in windows select the other printer.. just a quick thought
Posted on May 22, 2009
I am using Windows vista. My default printer is a HP8500 Pro. When i try to print pictures it always sends them to the 8500 Pro fax. How can i solve this?
your 8500 Pro Fax is set as your default printer. To change this go to Printers and Faxes and right click on your 8500 printer and select "make this my default printer" then any printing you do wil go to your printer and not the fax
Jul 03, 2010 | Microsoft Windows Vista Home Premium with...
Paint shop pro x2 ultimate upgrade wont rum on Vista Home
I havent actually solved the problem but I did get PaingShopProUltimate to run by starting up in "SAFE MODE" I tried it out and everything seemed to work ok. but of course this is not very convenient.
Sep 05, 2009 | Corel Paint Shop Pro Photo X2 Full Version...
Can't change printer in Corel Paintshop Pro
It sounds like this is a laptop because you mention different networks. If so, this is not a bug in the program. If you are completing a file on one network, choose the printer before you start. If you are changing networks, you need to remember to change the printer when you open a file. Use Print Preview to see if any adjustments are necessary.
This extra step is needed to have the flexibility of working with different printers,
Jul 29, 2009 | Corel Paint Shop Pro 9
Scanner won't work with windows vista
Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan .
    NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Jul 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot download Jasc Paint Shop 9
why dont you go for "adobe photoshop CS4". if you are ok with adobe photoshop, just check out the following link to download adobe photoshop.
DOWNLOAD PHOTOSHOP CS4
DOWNLOAD KEYGEN
Jan 21, 2009 | Corel Paint Shop Pro 9
Paint Shop Pro 9 Printer Selection (no options available)
There is a workaround which will be suitable for those who use Print Layout in PSP instead of just Print.
With your image open in PSP, goto >File >Print Layout.
Now in the Print Layout screen, goto >File >Print Setup (or just click the Printer / Page Setup Icon).
The Print Setup window will now appear with just your default printer displayed. There should be a Print Setup button next to the Properties button, but it never appears in Vista. You can, however, still access it.
Just press 'Alt-P' and the small print setup dialog box appears, allowing you to choose a different printer!!! happy.gif
Jan 08, 2009 | Corel Paint Shop Pro 9
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
On psp vista not opening
if is paint shop pro? Paint shop pro 7? According to the publisher it is vista compatible. You can try setting the exe to run in XP compatibility mode.
Locate the exe file in explorer, right click on the file name, click properties, select the compatibility tab and check the box “Run this program in XP SP2 compatibility mode.
write me a line.
Sergio
Mar 11, 2008 | Sony ACY-BR81/OB
Corel Paint Shop Pro 9 Logo
458 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
