Question about Harman Kardon AVR 240 Receiver
No sound from unit
Older system, 5 yrs. No sound for surround or radio either. Suggestions on what component might have gone out?
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Someone is trying to sell me a Panasonic Home Theater system SC-HT900 from year 2005 for $200.00 Is it a good system, is it also good for listening to classic and jazz or just for movies? how is the CD...
here it is some tech info ..it is a fair price for 2.hand unit...
as ebay has the similar prices..it seems to be a good deal...
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Product Features and Technical Details
  • Dolby Digital, Dolby Pro Logic II, and DTS-decoding home theater receiver with 5 speakers and a powered subwoofer
  • 35 watts per channel x 4 "tallboy" speakers, 140 watts for the center channel, and 150 watts for the subwoofer
  • High-resolution DVD-Audio playback; JPEG, MP3, and WMA CD playback
  • Magnetic shielding for distortion-free placement near a TV or computer monitor
  • Includes digital FM/AM tuner and a universal remote control
Technical Details
  • Brand Name: Panasonic
  • Model: SC-HT900
  • Output Wattage: 390
  • Component Type: Home theater system
  • Audio Output Mode: Surround Sound
  • Surround Sound Effects: Super Surround Sound
  • DVD Type: DVD changer
  • Built In Decoder: Dolby Pro Logic II, Dolby Digital, DTS decoder
  • Remote Control Description: Universal remote control
  • Optical Digital Input: Yes
  • Audio Input: None
  • Tuner Technology: Digital
  • Radio Bands Supported: AM/FM
Jun 21, 2011 | Panasonic Home Theater System System
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Sound Quality
Preferential Quality Connections in order of higher quality are: 1st>HDMI, 2nd>DVI, 3rd>Component/S-Video, 4th>Composite Video. Make sure you only use the surround setting on 1 of the 2 components, which ever is of better quality. If you use them both it WILL sound like mud. (older receiver-newer tv>probably tv) but you must connect all tv audio channel outputs to receiver. (newer receiver-older tv>receiver would be better)
Receivers also tend to have more wattage to drive larger speaker loads than most TVs. The key is to turn off the surround and SRS functions on the TV if you use the surround decoders on the receiver. Either way you use it, make sure you use the set-up feature to balance the outputs of the various channels for either source (the levels of the two will probably be very different).
Jun 11, 2008 | Panasonic SC-HT520 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Tape deck does nothing when play is pressed
Maybe a problem of no power to motor. I own 2 identical Aiwa units, both have tape deck problems. This brand is prone to them They also have nasty habit of tape cassette doors jamming.
1st off you never said how old the unit is. Awia have huge amount of models. Mine are the NX series that came out in black plastic. Most of the others are silver/grey. Honestly, unless you pop side screws and lift the cover off to eyeball anything loose. and none is? And if out of warrenty, the value of fix, mat exceed value of unit.
Sorry, but I see many of these,  of 4-5 yr old units Aiwa brand,
get the heave ho!
The most stupid thing about this is: for units size, has the best sound of any other brand it's size.. Brilliant for hooking to ones TV sets, for  surround sound!
What I did was get an older getto blaster  that plays tapes to play my tapes on. some of these units are around and in good order, dirt cheap. And most electronic equipment problems cost at least $35  just to have a quick look at your unit.. cost of repair on top?  I brought my 1st one new @ well over a grond. 3 yrs later, 2ns one, exactly the same $15.00 in a charity shop. The  laser unit was dusty. All go in half an hr. Perhaps if it is an older model , look for another mate to it,   It all comes down to costs.
Which is better option... you are the one who has to made the choice. Good luck. Jamz
Oct 25, 2007 | Aiwa NSX-AJ20 CD Shelf System
Harman Kardon AVR 240 Receiver Logo
32 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
