Question about Technics SU-G75 Amplifier
No sound from stereo
Hey all, I'm looking for some help as to why my old Technics SU-G75 amp isn't producing sound. All the settings are where they need to be, speaker button is on, volume is up, etc, etc. I removed the top to unit and it looks like some components overheated, see pic below. Looks like resistor 703 and 704 might be cooked? Don't know what would cause this. Could this be my problem? Is this a quick/ easy fix or am I better off retiring this old girl? Got it for Christmas about 20 years ago, I hate to get rid of it. Any help would be appreciated.
    Habit-Forming:
    New Friend:
  • 91 Answers
Greetings
the power module is damaged and the components ... as you described, resistors burned and other components are over heated .
you need a service technician if you are still hanging on your baby :)
unless you are a technician .i will be glad to send you send you schematic.
i cannot post it as(PDF).
Posted on Jan 02, 2016
4 Suggested Answers
SOURCE: Technics SU-G75
I had the same problem. The solution to me was presoldering transistor Q708. http://www.flickr.com/photos/37147023@N03/3511227679/?edited=1
Posted on May 08, 2009
  • 130 Answers
SOURCE: Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Posted on Dec 05, 2010
  • 794 Answers
SOURCE: i have a SU-G75 Technics stereo intergrated
Hi grayjt1963,
Based on the symptoms that you described this problem is caused by either of the two components. The most likely reason why you are getting no sound at all right now is the protect mode which your amp is in right now with the outputs turned off to prevent further damage. This unit have an AMP-Pac for the final stages that may be defective. The part number is RSN3306. This is the most likely part and can be purchased for about $60. Also inside is another AMP-Pac for the center and rear speakers (SVI3204B) which runs about $58. Either can cause the symptom you describe.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 28, 2011
Technics SU-G75 owners manual download
http://www.manualslib.com/manual/926367/Technics-Su-G75.html?page=2#manual Technics SU G75 Service Manual Page 2
Sep 23, 2015 | Technics SU-G75 Amplifier
Want to download Technics SU-G75 service manual
Technics will not give it to you. Gotta pay the piper!
Did you try to google it - might get lucky - but don't hold your breath.
Sep 21, 2015 | Technics SU-G75 Amplifier
How do i hook my speakers to my amp
Your amp has separate outputs for rear channels. Simply connect your rear speakers to the outlets on the back of your amp set up for them.
Jun 11, 2015 | Technics SU-G75 Amplifier
Technics SU-G75 has no sound
Hello
when the resistors are burned,means that the transistors are damaged, or the power module is damaged.
and in your case its the power module.
Hope this helps.
Feb 07, 2014 | Technics SU-G75 Amplifier
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Technics SU-G75 overload
I have the same problem..it will be required to remove the board and resolder "cold " solderings... None of above solutions have been helpful, but "you get what you paid for"..and I completely disagree...even if required, remove ALL audio power managing circuitry and replace this expensive original design with TI´s Integrated chips..using PWM technology..unless you want to go back to L6, ot Kts tubes..
Nov 07, 2012 | Technics SU-G75 Amplifier
Speakers for Technics SU X933?
check given link for speakers
http://www.fixya.com/myhome.aspx#Answers
Jun 05, 2012 | Technics SU-G75 Amplifier
I have a Technics stereo integrated amplifier SU G75. The cooling fan began making chirping noises then stopped. Now every time I turn the stereo on I get a overload message. Could it be the cooling fan...
It chirped because the bearings were worn out, then it froze up and isn't moving any air. Get it replaced. DO NOT run the unit if it keeps overloading or you will have a bigger problem.
Dec 27, 2009 | Technics SC-DV290 System
Technics SU-G75 Amplifier Logo
160 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
