Question about Crosman CR38-128 End seal 357/CO2 guns
Co2 seal kit - Crosman CR38-128 End seal 357/CO2 guns
What is involved with repairing a leaking 357 Crosman. What is in the kit ?
What's in the kits is listed here. Usually piston seal/Co2 seal, chamber o-ring and oil. There are videos showing how to do the repairs.
357 Crosman repair kit Bing images
Jun 18, 2016 | Optics
Crosman Z77
http://stevespages.com/pdf/crosman_z77.pdf
So my best advice would be take out all the 0-Rings etc and bring them to a local hardware store and get replacements but also the piercing piece may be worn down.
Jul 05, 2017 | Firearms
Crosman Z77
Sorry we have no parts reference materials here.
Jul 28, 2017 | Crosman Cars & Trucks
@centurylink.net I have a CO2 300 air rifle that I have for many, many years. When I put a CO2 carridge in it the air escapes before I can shot more that a couple BB's. I don't know if the air...
i am almost 100 percent sure that it is just a seal, CO2 is bad for drying out seals. Replace the seal and see if that fixes the problem, and if it does, go get some oil for firearms and put it on the seal before every 3 CO2 canisters.
Aug 10, 2011 | Daisy Toys
I was playing today and my 98 custom just started leaking CO2 from all the cracks it froze up and ice started coming out of the barrel. what happened and how can i fix it??
your tank loosened up, the co2 freezes the rubber seals they will have to be replaced, you can order a repair kit from the website, change out all the rubber seals on the gun and your co2 tank
Feb 17, 2011 | Tippmann 98 Custom Act Paintball Gun
I have a crosman 38t that I haven't used in awhile when I put they co2 cartridge in it leakses all out within seconds, what can I do???
It is likely some seals need to be replaced. I have had my 38 T for MANY years and have had the same problem. Seal kits are available, but not from Crosman. GOOGLE "Crosman 38 T seal kits" and you should be able to find where to order from. The cost is around$20+ for a complete set.
Btw, the reply from Norsky812 is waaay off the mark about the BB's. You clearly stated you have a Crosman 38 T, this gun shoots PELLETS.
Nov 14, 2009 | Crosman (4032)
Daisy CO2 200 pistol needs seals I think.
Try oiling it first. In the CO2 cartridge well, there is an oil spot. Put some 3-in-1 oil in that. If not, check out this link to see how to fix the seals on the pistol.
Oct 25, 2009 | Daisy Toys
CO2 ctge expels as it is inserted into handle
Your first problem may be your seals. if the base seals have not been oiled since you bought the gun they may have weakened or cracked to the point that they no longer make an effective seal against your 12g cartridge. For now, add some gun or machine oil. If that fails you can buy seal kits from whoever made your gun, and possibly have your local gunsmith install them if he is able to. This all depends on what the gun is worth to you.
Jan 17, 2008 | Optics
Crosman CR38-128 End seal 357/CO2 guns Logo
Top Crosman Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Crosman Tool and Hardware - Other Expert? Answer questions, earn points and help others
