Question about Irons
I need instructions for self cleaning the tefal aquaspeed 225 iron tks
SOURCE: Tefal Aquaspeed 160 Steam Iron
I have been able to rest the iron by simply moving the iron back and forth. try it.
Posted on Mar 26, 2008
SOURCE: Tefal self cleaning iron Ultraglide
Go to Sunbeam.com. They don't have this model - but there is an instruction manual for a 39?? - I read it and from what I remember it is the same as the 3957. It is a pdf file - page 8. - Those are the instructions.
Posted on May 12, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: I have lost the instructions
go to website by clicking below. Manuals can be printed from here.
http://www.tefal.co.uk/tefal/services/instructions.asp
Posted on Jan 06, 2009
SOURCE: how to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Posted on Apr 14, 2009
I need to know how to descale my iron
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 13, 2011 | Tefal Aquaspeed 155 Iron with Auto...
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
Clean the iron
can you not read properly i said i followed the manu advice on cleaning and no good
Dec 31, 2009 | Tefal Aquaspeed 170 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Tefal Aquaspeed 150
yes unless the thermostats gone.
It,s not really financially practical to replace parts, will cost you parts-and labour.
cheaper to get a new iron, unless still warranted.
Mike @ Compurepair.
Oct 01, 2007 | Tefal Aquaspeed 170 Iron
How to dismantle a Tefal Aquaspeed 150
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Irons Logo
95 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
