Question about Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon
Hank I thought my pressure switch was also bad. but I am on my second new one
  • eeawk May 19, 2009
    I redraind the new tank to reset pressure to 28Lbs. I put 45LBS into the tank to get read of all water and air if any was trapped. While waiting my gauge would climb to 10 - 15 Lbs while everything was shut down and off. No loss to tank pressure at all so it was not leaking.
    I then released the pressure in the tank to 28Lbs left the house out of the system. I then refiled the the tank with water at the 28Lbs turned on the water to drain and the have the pressure switch do its thing.
    It would drop to 29 Lbs and restart, but every now and then the pump would shut down at 30 Lbs and the contacts would stay contacted. it would stay off for a minuet then resart on its own?
    the pressure would drop to 0 and when it shut down. the house pressure would not go above 34Lbs.. I would attempted to adjust the larger screw for more cut off pressure but it would not do anything for me. I would have to put 35Lbs of air in the tank inorder to have any pressure in the house at all. no instructions one the smaller screw what is that for?
  • HANK MCNEIL May 11, 2010
    Please re-describe the symptoms and what happens - dosen't make sense.
    Note: comment on this listing instead of creating a new one so we have our past conversations before us please.
  • 332 Answers
Just a suggestion but your pump could be clogged in the ground, just by readind you are on well system? the contacts are together because they are trying to pull water to get up to the proper amount of water pressure. that is why they contact then overheat release then contact again, how old is the pump????
Posted on May 30, 2009
The heating element continues to heat even after the hot water tap is turned off thus popping the thermal switch. The red light is off on front of unit but you can hear the water heating. Any ideas?
check the pressure control that switches the element on or off
if it is faulty then it switches on when the tap is turned on dropping the pressure but it will not recognize that the increase in pressure when the tap is turned off so it keeps heating the water.
Apr 07, 2015 | Stiebel Eltron TEMPRA 24 Tankless Water...
I have installed a new water heater aruond two months ago. The problem is that the T&P valve keeps going off even with an expansion tank put on the water system. The water supplier has a built in check...
Expansion tank is supposed to stop over-expansion due to pressure.
The check valve will stop over-expansion from pushing pressure back into the supply line.
The real question is what is causing the pressure.
If your TP valve is bad that could cause problem.
If the thermostat is set very high, and there is frequent short-term use of hot water, that can cause heat to build up inside tank.
Solution:
Lift TP valve and let out pressure to see if there is something lodged in the valve.
Be careful of the scalding water.
Let the TP lever down slowly.
Next step would be replace TP valve.
Turn down thermostat to 120, or set to 130-5 if objective is to kill most bacteria.
Last. You might check that your expansion tank is correct for water heater.
Oct 31, 2010 | Rheem 81VP6S/430126 Water Heater
I have a Rheem water heater for a spa. Lately it's been intermitant whether it goes on not. Someone suggested that the gas company needed to install a lager meter/regulator as the heater isn't getting...
did the gas company check the pressure?
propane = "11" to 13" water collumn
natural gas = 3" to 4.5" water collumn
I have actually had the valve go bad, replaced, everything worked great.
also check the thermocouple. this is a cheap repair and the most common problem. if this doesn't solve the problem, then I would replace the gas valve. it is rare, but they do go bad. even had a bad one on a brand new water heater.
as far as water in the line, this too is very rare.
Sep 07, 2010 | Rheem Water Heater LP Gas Valve
I haye a power vent hot water heater that wont light . the fan continues to run what could be wrong
The problem is probably in the pressure switch. The switch is usually a round thing with a hose or two going to it.
You must figure out though if the vent is blocked or if the switch is bad. Check the vent outside to make sure that air is coming out. If no air or little air is coming out of the vent then your vent may be blocked and the pressure switch is keeping the burner from coming on because of that. If air flow is okay then the switch is probably bad. Replace the pressure switch.
heatman101
Mar 26, 2010 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Water pump cycles to often. When pump turns on, pressure gauge shoots up to 50 lbs right away without pumping much water.
Sounds like a well fed system with a pressure tank that has lost its air charge. Check for a water tank with a tire pressure type stem fitting, should also have a pressure gauge. Most newer tanks have a rubber diaphram inside to keep the air and water from mixing, but a lot of older ones don't and the newer ones will develope a leak that will produce the simpoms you describe. Try adding a few pounds of air pressure to the top of the tank and check for leaks. Warning: Compressed air can escape explosivly if the tank is badly rusted out but if your water pressure goes to 50# without the tank leaking, it should be safe to add up to 25# of air. The air charges the water system and allows the pump to shut off until enough water is used to lower the pressure back to set points on the control switch. It's not a good idea to adjust the set points on the switch unless all parts in the system have been checked for safety to the new pressures.
Aug 13, 2009 | Water Heaters
Led flashes 4 times indicating 'open pressure switch' I exchanged the pressure switch with an exact model and it still does the same thing. Doesn't heat up because of open PS
Sounds like the control board is the problem and not the pressure switch. I would do a continuity test on the new switch just in case you received a bad one.
Mar 19, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Amtrol ST-12-C THERM-X-TROL ASME Expansion Tank, 5 Gallon  Logo
149 people viewed this question
Top Amtrol Water Heaters Experts
Paul Carew
rayc588
Level 1 Expert
Are you an Amtrol Water Heater Expert? Answer questions, earn points and help others
