Question about HP PSC Photosmart 2355 All-in-One Printer
Paper Fedding Problem
Problem: 1. Remove the color cartridge and re-install.
2. and then insert paper, empty tray.
Some one said that the printer board failure.
Is it right?
  • 26 Answers
How to install ink cartiges
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Aug 27, 2011 | HP Photosmart C4280 Aio Printer
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
Printer isn't working correctly
To resolve this condition:
  1. Remove the power cable from the printer.
  2. Remove the paper tray from the printer.
  3. Remove the paper from the paper tray.
  4. Verify that the paper you're using has KODAK XTRALIFE Paper or a "G" inside a circle (for G600 series printer docks) on the back. Do not use 4- by 6-inch inkjet paper.
  5. Insert the paper tray into the printer.
  6. Open the color cartridge door, then remove the color cartridge.
  7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
  8. Install the color cartridge, and verify that it is fully engaged.
  9. Close the color cartridge door.
  10. Connect the power cable to the printer.
  11. Wait for the printer to initialize (the paper may eject automatically).
The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
If the problem persists, call 18002356325 to send camera for repair
Oct 28, 2009 | Cameras
My printer is only printing half the picture, one half comes out great and the other half has nothing
    NOTE: For the Photo Printer 500 and the G600 or G610 Printer Docks only, press the power button in addition to plugging in the power cable.
If the problem persists cal 1800 2356325 > for a repair
Oct 26, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
Only prints 1/3 of photo
Here are the steps:
1.Remove the power cable from the printer.
2.Remove the paper tray from the printer.
3.Verify that the paper you're using has KODAK XTRALIFE
Paper
4. Insert the paper tray into the printer.
5. Open the color cartridge door, then remove the color
cartridge.
6.Install the color cartridge, and verify that it is fully
engaged.
7.Close the color cartridge door.
8.Connect the power cable to the printer.
9.Wait for the printer to initialize
10. Make a print.
If issue persist, call 1.800.235.6325 for repair.
Thanks,
Neerak21
Sep 25, 2009 | Kodak EasyShare Printer Dock Series 3
My printer is only printing half the picture, what should I do?
Here are the steps:
3.Verify that the paper you're using has KODAK XTRALIFE Paper
5. Open the color cartridge door, then remove the color cartridge.
6.Install the color cartridge, and verify that it is fully engaged.
Sep 24, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Im getting a line through the photograph when the photo
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 28, 2009 | Kodak EasyShare Printer Dock Series 3
Installed a new cartridge in printer dock. Now it
Here are the steps:
Paper
cartridge.
engaged.
10. Make a print.
Thanks.
Regards,
Neerak21
Aug 03, 2009 | Kodak Office Equipment & Supplies
Blinking lite on a hp deskjet 970cxi printer
2 reasons.
1)paper jam internally. chk carefully.
2)paper sensor problem.
just moove a paper in tray &tell me green lite is glow/not?
Aug 11, 2008 | HP Office Equipment & Supplies
HP PSC Photosmart 2355 All-in-One Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
