Question about Hoover UH30010COM Bagged Vacuum
Vacuum won't start
The check bag lights come on and the vacuum will come on 3 seconds and won't turn on why does it do that?
  • 281 Answers
SOURCE: Hoover Vacuum Encore Supreme
You can try thehooverstore.com, or call a repair shop and I am sure they can order for you. Doubt that you will find a (#56511A01)manual tho. The hose part #43434268 and will sell for around $15 to $20. Dusting brush #43414145 $8 to $10. Extentsion tube #38634678 about $5. Furniture nozzle #38614029 about $5. Crevice tool #38617024 about about $5. Hope this helps.
Posted on Mar 03, 2008
erickg
  • 116 Answers
SOURCE: agitator turns but the vacuum doesn't pick up that well
ok it sounds like the vacuum line that goes to your brush is clogged partially. need to remove soem screws and get to it from the underneath. or try blowing through the line with compressed air or blower side of a vacuum. its usaully the smal flat veins that clogg right before it goes up into the tube that you connect to.
Posted on Apr 15, 2009
galati2k
  • 281 Answers
SOURCE: what size bag for this vacuum
type a bags its on the back up by the cord hanger
Posted on Apr 29, 2009
  • 273 Answers
SOURCE: hoover windtunnel self-propelled vacuum is not
have you cleaned the filters?
Posted on Jun 09, 2009
WonderTech
  • 268 Answers
SOURCE: I need instructions on how to change bag in a
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Posted on Feb 03, 2010
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
The bag light stays on, the bag is new, the vac keeps going off, Am I doing something wrong?
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA (control valve assembly) are clogged and simply need cleaned. This should be performed at an authorized Aerus Electrolux store only.
Second, check the afterfilter. This should be changed after every six bags. It's located beneath the tool caddy on the back of the machine. Press in the tab and lift tool caddy. If the filter is dirty, remove and replace. If you're out, try running the vacuum with no afterfilter.
I mentioned the CVA earlier, and a broken or worn out CVA will cause the vacuum to not start/run. This is an internal part and needs to be replaced by an authorized Aerus Electrolux service tech. Use the same check as above; detach hose, switch vacuum on. If it doesn't come on, it's most likely a bad CVA.
Jan 03, 2011 | Electrolux Epic 6500 Vacuum
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Oct 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover UH30010COM Bagged Vacuum Logo
35 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
