Question about Canon Office Equipment & Supplies
I have a Canon IR6570 photocopier . Image problems.
I have a Canon IR6570 photocopier .When I attempt to produce double sided copies half of the image is missing( on either side it seems to fade away )Strangely this seems to happen when using white A4 paper - coloured paper or any A3 is fine. I have tried changing the white A4 with another brand but the results were the same.Any suggestions? Thanks - Martin.
E0225-0001 salve this probluem
Posted on Dec 28, 2009
    Sergeant:
  • 199 Answers
There are sepration carona creating problem, replace carona wires
Posted on May 22, 2009
How can i fix the the problem with canon ir 4570 which produce an image the half is good and the other is bad . i already change the drum .
Hi. You need to be more specific. Printed paged are OK or it's just when making copies . If both copies and prints are bad . The problem can be in the printer section but if only copies are bad the problem is in the scanning section .
May 20, 2017 | Canon Office Equipment & Supplies
Why is my printer so slow when photocopying, print from laptop is fine, and why is photocopied image larger than original
I have an Epson SX405 and it has been getting slower and slower since I got a Windows 7 laptop.
Finally discovered (a tip from another help site) the AUD file in C:\ProgramData\Epson\PRINTER. The bigger it grows, the slower it gets.
So just delete that file. The driver will create another one next time you print, but nice and small.
After that, keep deleting it from time to time, before it gets big again.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
May 17, 2014 | Epson Office Equipment & Supplies
My Canon PC 1060 makes copies with a double-image of the original, about one-half inch apart, so they are very smudgy and bleary. Also, the ADF does not work; I wonder if that is related? Any advice?
You a get a technichian to look at your machine simply becouse you might not know where the problem is even if I instruct you, however note this:-
The problem is with the fixing unit, the fuser membrane is one at faulty no wonder double images therefore change the fuser membrane the problem is gone. the fixing unit is where the copy paper pass and the pressure roller together with the membrane enables the image to be permanent on paper, sometimes you just need to clean the rollers using silicon oil i.e. the pressure roller and the membrane.
Jul 31, 2011 | Canon PC-1060 Black and White Copier
Photocopier producing skewed finished copies. What can be the problem?
If the image is skewed on your paper, you have a registration bushing broken.
If the image is OK on the paper, look for a piece of paper or a little thing in the way of copy
Jun 27, 2011 | Ricoh Aficio MP 1600L Black and White...
How to scan in two faces in one side for exmaple ID in photocopy scan and printer " canon IR3045N"
select special function on screen>image combination>2 on 1>original size a5R(if u r copying on a4R paper then original size a5) then scan both faces to be printed and >done
Feb 03, 2011 | Canon Office Equipment & Supplies
When copying by putting the original thru the machine, half the copy come out solid black. Putting it on the glass under the lid the copy comes out perfect. Any ideas why this is happening? How can I...
A user default
1.The printer is possibly not designed to perform in color copying through the machine feeder area, only on the photograhic image scan area. Discontinue scanning the image in feed area.
A Technical default
1. The device is nearly out of ink
2. The device printing bands are clogged requires cleaning
A printing material defect
1. The positioning of the medium to be photocopied only achieves success when layed flat on the screen. Possible images are likely when lightening does not escpe in the process.
Consider, using an alternative copy machine that would achieve success.
contact technical expert, soon as possible
Dec 01, 2010 | Canon LaserCLASS 510 Printer
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Not photocopying
Open side, look at black assembly on the door, there is either a black spongy roller there or two wires in a black assembly,
1- wires may be broken resulting in blank copies
2- roller out of place
3- HVT (high voltage transformer) not working
Jun 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
430 people viewed this question
old marine
old marine
