Question about Symantec Norton Internet Security 2008: Windows
We have nis 2008 i am not able to install in windows 7 suggestion pls
  • 400 Answers
What error do you get?
It seems the 2009 version is compatible by installing a compatibility update via live update:
http://www.symantec.com/norton/theme.jsp?themeid=windows7
Posted on May 19, 2009
I need to install a tally on windows server 2008R2.... so pls suggest me, which version of Tally is a recommended...... Thanks
Hiiii,
Server 2008 R2 is not available for tally its need TAlly patch so reinstalled Tally ERP 9
Regards,
Jagjit Mishra
May 18, 2011 | Computers & Internet
Tip
How to disable and re-enable hibernation on a computer that is running Windows
The Hiberfil.sys hidden system file is located in the root folder of the drive where the operating system is installed. The Windows Kernel Power Manager reserves this file when you install Microsoft Windows. The size of this file is approximately equal to the amount of random access memory (RAM) that is installed on the computer.
The computer uses the Hiberfil.sys file to store a copy of the system memory on the hard disk when the hybrid sleep setting is turned on. If this file is not present, the computer cannot hibernate.
Hibernation is made unavailable when you set the value of the Hibernate after setting to Never by using the Power Options item in Control Panel. To make hibernation unavailable, follow these steps:
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt, and then click Run as Administrator.
When you are prompted by User Account Control, click Continue.
At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
Type exit, and then press ENTER.
To make hibernation available, follow these steps:
At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Type exit, and then press ENTER to close the Command Prompt window.
APPLIES TO
Windows Vista Business
Windows Vista Enterprise
Windows Vista Home Basic
Windows Vista Home Premium
Windows Vista Starter
Windows Vista Ultimate
Windows Server 2008 Datacenter without Hyper-V
Windows Server 2008 Enterprise without Hyper-V
Windows Server 2008 for Itanium-Based Systems
Windows Server 2008 Standard without Hyper-V
Windows Web Server 2008
Windows Server 2008 R2 Datacenter
Windows Server 2008 R2 Enterprise
Windows Server 2008 R2 Standard
Windows 7 Enterprise
Windows 7 Enterprise N
Windows 7 Professional
Windows 7 Professional N
Windows 7 Ultimate
Windows 7 Ultimate N
http://support.microsoft.com/kb/920730
on Nov 19, 2013 | Microsoft Windows Vista Home Premium with...
How to install pagemake 6.5 on win 7 pls do help me
Hi there!
Adobe PageMaker Plus 6.5 is for Win2K computers. It is not compatible with Windows 7. I suggest an upgrade of your software to Adobe InDesign, which is compatible with Windows 7.
Hope this helps.
Apr 25, 2011 | Adobe PageMaker Plus 6.5 for PC
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
Oct 15, 2010 | Dell Dimension 4700 PC Desktop
Belkin bluetooth mouse unable to work with windows 7
try installing the driver for mouse in a compatibility mode....
rightclick on driver file >properties >select compatibility tab > check mark in the checkbox "run this program compatible for" and select windows xp....
guess it ll work fine....
good day....
Mar 03, 2010 | Belkin Bluetooth f8t041-b Mouse
Window7 installation
1) you have to make sure that you have ALL the required Windows 7 drivers for your Laptop AND additional devices/application (eg. Wifi adapter, Modems, USB DTV, External Keyboard, etc). 2) get and install a 'Windows 7 UPGRADE' for your current Operating system. (Check for free upgrade?) 3) Windows XP mode (and native Virtual PC) is only available if you upgrade to the Professional or Ultimate versions AND your CPU and BIOS support 'Hardware Virtualization' ... even my Intel Dual Core T4200 processor does not support this feature!!!
Hope it helps: let me know how you go!
Jan 01, 2010 | Toshiba Satellite A100-S8111TD Notebook
Full system scan not getting completed
Open NIS and run LiveUpdate. Keep re-running LiveUpdate until it says that there are no more updates. Reboot the system if prompted to do so (you may want to reboot even if it doesn't say it is required, just to be sure everything got replaced properly). Open NIS again, select Tasks and run a Full System Scan. The error message should not appear again.
Mar 19, 2009 | Symantec Norton Internet Security 2008:...
NIS 2009 upgrade
I was able to uninstall NIS 2009 and Re install NIS 2008 without my initial settings being affected, which is what I was concerned with when I contacted you guys.
Nov 15, 2008 | Norton Internet Security 2005...
Upgrading NIS 2006 to NIS 2008
You paid for the key and now the key will not work right??
If you have the reciept you should be able to get onto customer assistance and get a new key.
Or you could try a free virus protection like 'AVG free'.
cheers
Emmanuel
Sep 10, 2008 | Norton Internet Security 2005...
Symantec Norton Internet Security 2008: Windows Logo
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
