Question about Remington R5130
Re-assembly of R5130 rotary/flex heads.
I need assembly diagram & instruction for rotary/flex heads. Also, need 3 tiny springs for under each rotary/flex head.
SOURCE: After two weeks use of my new Remington R5130, now
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Posted on Sep 01, 2009
brector3
  • 1610 Answers
SOURCE: screen replacement
You will find instructions at shaveroutlet.com. See link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_23_2.jpg
Posted on Jan 26, 2010
brector3
  • 1610 Answers
SOURCE: i am replacing blades for remington r5130. i
You do NOT need to remove the screw. The blades and comes are removed from the top so it is not necessary to take anything out from the underside.
Instructions should be included on the back of the pckage that the replacement heads came in. You can view the instructions at the link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_36_1.jpg
Posted on Aug 22, 2010
brector3
  • 1610 Answers
SOURCE: Re Remington electric shaver R5130, "User &
The outer combs must be turned first so that they can be removed. You will find instructions posted at shaveroutlet.com. See link below
Posted on Nov 14, 2010
brector3
  • 1610 Answers
SOURCE: I have a Remington 360
These springs are not available from Remington for replacement. Your best bet is to go to your local hardware store where they should have a variety of springs available
Posted on Sep 02, 2011
How often should i change razor blades
Remington suggests changing the blades every 12 months on model R5103. If replacements are needed, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Mar 02, 2011 | Remington R5130
We cannot find our warranty paper on this model from Remington razor R5130. It broke at the place where the top connects to the razor. We purchased the razor several months ago for our Hospital use for...
If you purchased it less than 2 years ago, it is still under warranty. If you have proof of purchase, you should be able to call Remington at 1-800-736-4648 for additional warranty instructions
If you are not able to show proof of purchase and are not able to use the warranty, you will find the needed part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-head-assembly-without-cutters-for-select-models-p-808.html
Jan 04, 2011 | Remington R5130
Nov 13, 2010 | Remington R5130
I am replacing blades for remington r5130. i removed the middle screw. plastic bracket doesn't want to come out. Is there a trick to remove the bracket to replace the heads?
Aug 22, 2010 | Remington R5130
How do you install the shaver heads?
You will find replacement heads for model R5130 at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-sp5161-flex-360-titanium-replacement-head-with-teflon-p-590.html
Installation instructions are on the back of the package. You can also view thm at shaveroutlet.com with the link below
Jul 12, 2010 | Remington R5130
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
Two points.
Jul 08, 2009 | Remington R510 Electric Shaver
Dremel Flex shaft attachment model 225
Dremel has an exchange program for the 225 Flex Shaft. Send your flex shaft and 17.90 and they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264 Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 09, 2008 | Dremel Variable - Speed Multipro Rotary...
Remington R5130 Logo
51 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
