Question about Brother MFC Office Equipment & Supplies
Brother mfcj6510dw out of alignment after adjusting
Brother printer out of alignment after adjusting
Print head alignment
If it is a brother inkjet machine, you should go through the ink management system on the printer. Find the print test option, drop down to alignment, and then follow the instructions printed and given by the printer. If the alignment is way off, you may need to repeat the process 2 or 3 times.
Apr 04, 2014 | Brother Office Equipment & Supplies
Katiaonody1@gmail.com
The LC1240 is INK mot Printer Model. The model is MFCJ6510DW and you can find all downloads at SOLUTIONS.BROTHER.COM and select your continent and operating system and download
Mar 21, 2014 | Brother Lc1240 / Lc1220 Set Of 4 Compat...
I need brother printer maintenance codes
Check the site:
http://office.manualsonline.com/manuals/mfg/brother/brother_mfc_970_br970.html
to get printed information on the printer.
Feb 17, 2013 | Brother MFCJ6510DW AllInOne Inkjet Printer
Black black and blue ink printing over shadow and blurry
Pull out the ink cartridges and wipe the print heads with a clean rag and alchohol. Then replace the cartridges. Then go into the printer "Properties" by clicking on the "Printer listing" in the "Control Panel" listing if you are using Windows XP then select "Printers and Faxes" that will open a window with your printer name listed on it. At this point "Right Click" the printer in question and Select "Properties" from the short menu. Depending on your printer model you may need to then select "Printing Preferences" that will display various tabs , at this point Select the Maintenance tab and under services Select "Nozzle Head" or Head Cleaning or once for each if both are listed. That should clear the problem. If not, you may need to replace the cartridges using the OEM specified replacements. Good Luck and Happy New Year.
My name is Ed Pinero and I am a 10 year IT veteran and Field technician
Dec 29, 2012 | Brother MFCJ6510DW AllInOne Inkjet Printer
Printer says paper jam but no paper is jammed
open back or bottom and see if there are small pieces of paper stuck in there then report findings please
May 16, 2012 | Brother MFCJ6510DW AllInOne Inkjet Printer
My Brother 3240c prints/copies everything in double vision. I have tried to adjust alignment, no change
The printer head needs to be replaced. Check the brother web site for an authorized service center
Mar 28, 2010 | Brother MFC-3240C All-In-One InkJet...
I have a brother LH2040 printer that won't print
My red light flashing problem on myHL-2040 was caused bythe plastic horizontal rod out of alignment in the back ofthe printer. Steps: 1. Open the back cover. 2. Gently pull the tab toward toopen the Rear Chute Cover (plasticflap) inside (page 78 of User's Manual). 3. Look closely at the bottom rod ofthe Rear Chute Cover tomake sure everything is aligned. The two"tabs"(one long and one very short) on this rod should fit right into theallocatedslots. 4. If not, adjust the rod so theright end extension of therod will block the paper sensor when the chute coveris pushed in by the backcover. Hope this helps - I wasted hourstrying to fix this problem.
Mar 31, 2009 | Brother HL-2040 Laser Printer
Copy paper feeder alignment
You need to call a Service Technician, You need to do a Registration adjustment and A Service Tech who is Brother authorized will know how to do it ?
Your registration is off.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Printer alignment
From Brother's website, I found the following regarding alignment:
Setting the Alignment:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
The webpage for this is:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000059/faq000259_007.html?reg=us&c=us&lang=en&prod=mfc420cn_us
I hope this resolves your problem.
May 20, 2008 | Brother MFC 420CN All-In-One InkJet...
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
