Question about Sharp AL 1631 Copier
My sharp sf 2022 machine, i need solution
   my name are clement charles ugoji and from nigeria, i am an engineer by profession and i deal on sharp machine.
   please i need an assistance my sf 2022 sharp analog photocopier machine flash F2 ,and then maintenance (b) Required please what should i do.
 i also want to join your organisation so as to been an engineer in your company in nigeria or any of te country.
  i will be delightad if my apply will be granted
        yours faithfull
        Engr clem ugoji
        TEL- 2348058422903
My toner collecting container need cleaning.where can it be found
Posted on Mar 22, 2008
  • 163 Answers
Mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Posted on Oct 18, 2007
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Model sf-2022 not running shows f1 on key pad
If you hold down the copy button, the machine will flash a set of two more digits at you. Check out what the digits are then compare your problem with this chart =].\
00 Sorter communication trouble detected
01 Paper jog malfunction detected
02 Transport motor malfunction detected
04 Indexer lower limit detected
05 Indexer upper limit detected
06 Shift motor malfunction detected
Aug 09, 2009 | Sharp Office Equipment & Supplies
Need sharp sf2027 user manual - want to be able to use copier as a pc printer & fax - how do we set this up?
Hi, Are you sure the machine you're talking about is a Sharp SF 2027? If so that machine is an analog machine and cannot be used as a fax and/or a printer.
Hope that helps...
Jul 17, 2009 | Sharp Office Equipment & Supplies
I have a Sharp SF-2022 copier and it flashes a U6 code abd will not work. How do I fix this?
u6 is sually something to do with the papaer tray or feed section check to make sure the tray is set properly and that you have the guide plates set correctly and that the tray is fully set
Jun 11, 2009 | Sharp AL 1631 Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
I dont have the exact manually for this machine although most of the sharp error codes are consistant for most newer models. L1 refers to the scanner area of the machine. The scanner is a part that looks at your original by shinning a light across the page and tranfering that to the machine with mirrors. If you lift the lid and push the print button, you will see it under the glass. Something may be blocking its movement if you hear an unusually noise when trying to print. If no noise it could be a sensor, motor, or a circuit board.
Nov 01, 2008 | Sharp SF 2020 Copier
Your toner cartridge needs to be replaced, It is empty.
Mar 31, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
588 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
