Question about Air Conditioning and Heat for Ford E350
Ford club wagon rear coolant lines leaking
Overheating no heat
shanat
  • 359 Answers
SOURCE: 2003 ford focus station wagon
have your waterpump checked also thermostat flush radiator and renew the cap make sure your thermo fans are functioning
Posted on Jun 02, 2008
SOURCE: No front heat
where is the heat blend door located 97 ford e-350 van
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: 1999 Ford Windstar 3.8 no heat
If you have a knock or clicking noise behind the radio, it is the blend motor. The blend door is spring loaded and the gears in the blend motor are "stripped". The door is spring loaded so that the door is closed to the heater core. About 2 hours to replace and a lot of bending and stretching. You don't have to remove the dash, but all of the trim, radio, and controls will need to come out.
Posted on Mar 01, 2009
asetech74
  • 218 Answers
SOURCE: how do you change a fuel filter on a 1998 e-150
This fuel filter has snap lock type fittings on the ends of the fuel filter, you need a fuel line disconnect tool to remove the filter, you will insert the tool into the hose ends at the snap locks, push in on the fuel line while pushing the tool into the fitting then you can slide the fitting off the fuel filter assembly. Hope this helps
Posted on Jul 12, 2009
  • 324 Answers
SOURCE: need fuse box info for 1993 ford club wagon
There are two fuse panels, or power distribution boxes. The engine compartment power distribution box is located on the left hand side of the engine compartment above the wheel well, and the central (inside) power distribution box is located under the LH side of the dash, left of the steering column.
Posted on Oct 06, 2009
1991 ford club wagon is over heating
Replace thermostat and check operation of cooling fan.
Mar 23, 2014 | 1991 Ford E-250 Econoline Club Wagon Light...
I'm curious how difficult it is to replace a thermostat on a 1997 Ford Econoline. I believe the blower is working, but there's no heat as of a few weeks ago. Earlier this summer I flushed the coolant...
check your heater core hoses to see if they are both hot if one is cold try just flushing out your heater core.if its doesnt work your heater core maybe bad. the thermostat would run with the top radiator hose to on top the block. its not really hard if there nothing in the way of it
Oct 23, 2013 | 1997 - 2002 Ford E-150 Econoline Club...
1992 ford club wagon no rear air out of top vents
The blend door is vacuum operated.
Oct 24, 2012 | Cars & Trucks
KIA SEDONA HAS REAR HEAT BUT NOT FRONT HEAT BLOWERS WORK BUT ONLY COLD AIR COMES IN FRONT
This could be a serious problem. Check your coolant level, then check the rear heater lines that supply coolant to the rear heater. They run under the van, over time they rust and leak. Because it is under and to the rear of the van it is hard to notice, i.e. coolant puddles and smell. But please note that this engine has aluminum cylinder heads and does not take kindly to being overheated.
Jan 08, 2010 | 2004 Kia Sedona
I need a diagram of a fuse box for a 1993 ford club wagon
Instead of spending $20.00 on the 1993 ford wagon fix it book check by the fuse panel under the steering wheel or on the foot well of the passenger side. If none available the look on line at ford parts type in make and model and look for diagrams of the fuse panel.
Nov 06, 2009 | 1993 Ford Club Extended
1998 Ford Club xlt, tranny fluid leak in the coolant.
The lines for the transmission cooler run to the reservoir on one side of the radiator, correct? You may have gotten a bad radiator and the trans cooler is allowing the fluids to mix.
Jan 31, 2009 | 1994 Ford Club XLT
No front heat
Jan 29, 2009 | 1997 Ford Econoline
2003 kia sedona over heating and no heat
Check your rear coolant lines, These lines always rust and start leaking coolant and thats why your engine over heats and you dont get any heat inside your car. This is a common problem with kia sedona that have rear A/C and Heater. There are two fixes to this problem. The first is to replace the rear heater coolant lines with the updated lines from kia. The second will be bypassing the rear coolant lines with a hose, however the rear heater will not work with this method.
removing the rear coolant lines is not that easy. The lines near the fire wall are really hard to remove. Its also much easier to replace the lines with the car on a hoist.
hope that helpfull
Kia mechanic
Dec 29, 2008 | 2003 Kia Sedona
Air Conditioning and Heat for Ford E350 Logo
19 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
