Question about Philips 13PF7835 13 in. LCD Television
Sound is fine from DVD and video but no picture
Turned on the TV this morning and could hear the sound coming through the speakers ok but there is no picture from the VCR or the DVD player. Can't pick up a signal for normal TV stations either. Have made sure the scarts are all connected properly as this has solved this problem in the past. However, this did not resolve the problem. The TV is about 5 years old so don't know if it's just reached the end of its life.
Any clues as to why this has happened
  • sgooch883 May 19, 2009
    Will check that out - thanks a lot!
SOURCE: no sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Posted on Jan 16, 2008
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Posted on Sep 28, 2008
SOURCE: Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Posted on Feb 03, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can't hear sound on Windows Mediaplayer from DVD I recorded
I've been pondering this one for a day or so - at least two possibilities:
1) There is a mute/audio-off hotbutton inside Windows Media Player itself - click on it and see if the audio works. Alternatively, you can try playing a music file in Windows Media Player to see if THAT file has sound.
2) You need a better Codec - the free version of the K-Lite Codec has limited audio support. There are no easy answers to this problem. I frequently use my computer for converting VHS's to DVD, so I finally plunked down the $50 to purchase Nero 9 and all of its codecs. Before that, however, I used VLC Media Player (free) - it has DVD/VOB audio support.
As a side note, if you wanted to use your computer to convert the VHS's to DVD, you would need a plain-old VCR, a red/white/yellow cable, a DVD burner, and a product called the Dazzle DVD Recorder from Pinnacle. You can hook the VCR straight to your computer and burn away. To get the best experience however, I would also get a program like Nero, Roxio, etc. to do the actual DVD burning (although the Dazzle's native software is perfectly capable of doing the job).
-Tha Mp3 Doctor
Posted on Feb 15, 2009
pwrblnc
  • 4 Answers
SOURCE: TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
Have sound no picture in tv mode and dvd.
Hello from Venezuela, it's possible that speaker is bad, open the tv and find a tester, wiht the tester in beep continuity test mode and the tv off, put in the speaker terminals the pins off tester respectibly, in the tester screen must view something like this: 7.95 to 8.20 or 3.80 to 4.10. And must hear a beep sound from tester, it means the speaker is ok.
If not, the built in sound amplier is provably bad and you must change the aplifier IC with a experience o certified thecnician...
About the video could be a fail in the audio video mixer of tv try replaceit....
Att: Eduard.
May 23, 2015 | Audiovox VE1020 10.2 in. TV/DVD Combo
Suddenly no sound is coming from the tv
Unplug set and or a box if used for a while and plug back to let units reboot.
Look in menu to see if speakers are switched on or off.
Look to see if a DVD etc connected to a rear input has sound or not.
May 29, 2012 | Toshiba Televison & Video
Knock or Bang
I would try to localize where the sound is coming from--take back off and listen when set is turned on---from speakers or from inside the TV.
Apr 03, 2012 | Televison & Video
Toshiba 36a43 i have picture but no sound. Volume control works but again still no sound.
Things to check:
In menu are speakers (audio area) switched on or off?
If you put sound all the way up and listen right at speaker what if anything do you hear?
If using a cable or sat box is sound turned down on it?
Is sound muted on set or the box (if used)
Do you have sound with a DVD etc hooked via the rear jacks?
A few sets have a slide switch on the rear= internal or external speakers--is it set to internal?
failing all of the above you have a audio circuit problem
Mar 26, 2012 | Toshiba 36A43 36" TV
Can't hear sound through tv when dvd is playing
I would look in the tv menu and see if the speaker audio on the tv have been turned off.
Aug 09, 2009 | Televison & Video
Sharp Aquos LC-26D4U sound problem
You want me to tell you how I fixed it for free, but you don't want to help me for free. What's with that?
Aug 01, 2008 | Televison & Video
I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
Feb 09, 2007 | Eltax DV-100 DVD Player
Sound quit working
You didn't mention if you were using the TV with a cable or satellite TV box which could have its sound turned down or be defective. Otherwise, if you have a VCR or DVD hooked up to the set, do you get sound then? With some TV's there is a menu selection where you can turn the speakers off and on some sets, there is a switch to mute the speakers. If you still can't get sound and the set is out of warranty, then a replacement is probably in order.
Dec 19, 2006 | Philips 14MS2331 14" TV
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips 13PF7835 13 in. LCD Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
