Question about C. Crane CCRadio-EP AM/FM Radio w/ Lighted Needle & Dial
CCRadio-EP Tuner Knob just spins without moving
Made in China - Says No user serviceable parts inside. What size screwdriver needed to open radio
CCRadio-EP Tuner Knob Spinning and not moving tuner dial
Get a set of screw drivers of different dimensions and shapes and try each one until you find the right one.
Dec 29, 2013 | C. Crane CCRadio-EP AM/FM Radio w/ Lighted...
Tuning knob turns but does not move tuner bar nor change station. all else works fine.
The linkage between the tuning knob and tuner bar (string?) has failed. Disassembly will be required to repair.
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Tuner not working
You mean a digital tuner or an analog tuner (the old ones with the cursor)?
Post for reply.
Stelios.
Feb 23, 2010 | Proton R5A Clock Radio
Where can I procure parts for a WF203 model TV. The part that receives the coax cable is broken and I need to replace it
Try ued.net you'll need make and model numbers, depending on how old tv is it could be either a antenna isolator or a tuner.
Aug 05, 2009 | Televison & Video
Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Jan 10, 2009 | Hardware & Accessories
Digital radio
try moving your tuner button it may work
Feb 11, 2008 | Audio Players & Recorders
Speaker noise
The contacts on the volume control (potentiometer) get oxidized over time on any analog rotary volume control. With the power off, crank the volume control back and forth real fast for a minute or two, this will do the most cleaning of the contacts that you can do without access to the insides. Ultimately you'll probably need to sprary some tuner wash/tuner cleaner or other electronic parts cleaner in the know (with the electricity disconnected) and then work the knob back and forth. Tuner wash bottles are available at electronic specialty stores or radio shack and usually have a long extension tube (like what comes with WD40). You might be surprised where you can reach with the extension tube.
Sep 01, 2007 | Boston Acoustics BA745 Computer Speakers
C. Crane CCRadio-EP AM/FM Radio w/ Lighted Needle & Dial Logo
Top C. Crane Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a C. Crane Audio Player and Recorder Expert? Answer questions, earn points and help others
