Question about Kenmore 63932 Electric Dryer
I have a kenmore 70 series dryer model # 110.62702100 it wont turn on you can hear the timer going. i checked the belt and its not broken and its tight, ive also tried holding the button in and st
If this helps the SER# is- ML 110811 and the TYPE is- DWSR-ELE-2406028-FM54
vickygomar
  • 460 Answers
SOURCE: Kenmore electric dryer Mod. 100.66662501, type
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
Posted on May 13, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My dryer won't turn on
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
Posted on Sep 26, 2009
SOURCE: Where do you find a heating element for a Kenmore
partsdirect.com They will have every part on it.
Posted on Nov 10, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore electric dryer DWJR-ELE-2406028-FM54 Model
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 10, 2011
oldTech2332
  • 2341 Answers
SOURCE: how to change a heating
This video will show ya how to replace that heat element
Posted on Sep 17, 2011
Kenmore dryer doesn't turn on and belt broken. I can hear timer on if I hold start button on. If belt was only problem wouldn't dryer motor still turn on
It depends on the model on some models they have a belt switch so that when the belt breaks the switch kills power to the motor and it wont run until the belt is replaced and the switch is engaged. If you need more help with making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 25, 2017 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My kenmore 70 series dryer will not start what could the problem be?
bad fuse. do you have a lint screen on top of the lid or in the door? if it is on top remove the back panel make sure that you have removed power to the unit you will see a white line peice with 2 wires attached that is your fuse check to see if you have continuity. if not replace your fuse. if that is not your problem you could have a broken belt or a bad timer. let me know if the fuse is ok first though,
Aug 19, 2009 | Dryers
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Kenmore 63932 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
