Question about Denon AVR-1508 Receiver
How do i hook up a sound bar to a Denon AVR-1913 receiver?
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
SOURCE: hooking up an external audio source (IPOD) to the Denon AVR 3803
sure
just get a cable with phono plugs to mini phone connector Radio shack has them
Connect teh mini phone to teh earphone jack adn teh phono plugs to the aux inputs
select aux and enjoy
Posted on Jan 07, 2009
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
Unlock the sound settings lock
On my Denon 1913 under the general setting in setup is a setup lock option. Mine is set to "OFF" . You need to find a similar option on your receiver and be sure it's set to "OFF".
Sep 19, 2014 | Denon AVR-2802
How do i connect sonos " control " to denon avr 300. Where are audio output on this denon?
The AVR-E300 doesn't have an audio output. It's a very basic AV receiver built down to a price.
Even if you has a better quality receiver, you still would only be able to port sound from analogue sources (ones connected via red & white RCA/phono) to the Sonos Connect for distribution around the rest of your home. AV receivers don't decode audio from HDMI sources to analogue stereo.
If you want to port sound, hook up a source direct to the Sonos Connect's audio input. Don't try going via the receiver.
Sep 14, 2014 | Denon Audio Players & Recorders
How to reset denon avr 1913
Is thereany sign of power? relay click or anything?
Jun 07, 2014 | Denon AVR 1913 71 Channel 3D Home Theater...
Pandora activation code
From Denon website!
http://usa.denon.com/us/news/pages/newsdetails.aspx?newstype=news&newsid=89&year=2012
Dec 01, 2012 | Denon Avr-1913 - 7.1 Ch. 3d Pass-through &...
I need help configuring my denon avr 2801 receiver, im trying to hook it up to my tv for surround sound
Just moved and got mine hooked up last week. Was working great and now I can't get anything. The reassuring "click" I've always heard when I switch between inputs is gone. Anyway enough about my issue, what specifically are you having trouble with?
Sep 06, 2010 | Denon AVR-2801 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
Denon AVR-1508 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
