Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Electrolux Refrigerator Model ERL6297XS1
My appliance only works for approx. two weeks at a time - it gradually gets noisier and makes clicking sounds and then both fridge and freezer temperatures rise. If I turn off for a day or so, it works fine for another two weeks and then the fault occurs again. Do you have any idea what may be the cause, I have had service people look at it but no cure as yet?
woodchuck789
  • 4059 Answers
SOURCE: I have a 4-yr old Electrolux 22.6 counter-depth
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Jan 07, 2010
  • 37 Answers
SOURCE: electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Posted on Jan 09, 2010
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
SOURCE: electrolux frost free fridge freezer
The evaporator drain can become blocked. Water backs up and eventually falls out into the freezer and freezes. If this happens you should see ice build up inside the freezer.
The evaporator heater can blow. This allows condensation to freeze and not drain away. I have tried replacing it but I cannot confirm that I have solved the problem.
Another problem is liquid water draining onto the fan in the freezer compartment near the evaporator. If this happens when the fan is idle (presumably when the fridge and freezer are both down to the right temperature, water falling on the fan blades will freeze. The motor is low power and it may not have enough torque (turning power) to overcome the imbalance. This stops the cold air from circulating to the freezer and fridge. The control circuit may detect the fan is not turning or the temperature may rise setting off the alarm.
I have an Electrolux ER3162BN fridge freezer.
Posted on Jun 26, 2010
machinetech7
  • 1344 Answers
SOURCE: The Electrolux refrigerator is not
First thing to check is if (a) the evaporator fan is running in the freezer and (b) if there is a build up of ice on the freezer wall. If the fan is not running in the freezer the ref. side won't cool. If there is a build up of ice on the freezer wall, then you a defrost system problem and there won't be any circulation to the ref. side. If you have a defrost problem, the defrost system consist of 3 parts: timer, bi-metal thermostat, and heaters. With fridgidaire more than likely the adaptive defrost board(timer) located in the fridge on the upper left side behide some white pastic is bad. If you change it go ahead and change the bi-metal thermostat, located behind the freezer wall, as well because its a very cheap part and will save you from having to do it later.
Posted on Nov 01, 2010
Is the Kenmore French door refrigerator 70413 a good reliable refrigerator?
best advice -- there are other makes on the market so shop around and read reviews
don't buy it just because you like the name especially when you are aware of problems in the make and model
Apr 07, 2015 | Kenmore Refrigerators
My Electrolux Diswasher Model EIDW5705PS is stuck in Loc mode
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5705PS, keeps getting stuck in LOC mode. I also see that you are looking for another way to reset it, other than having to uninstall it. First, I suggest trying to unlock your appliance by pressing and holding down the "Air Dry" button for 3-5 seconds. If that doesn't work, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Electrolux EIDW5705PS 24" Stainless Steel...
Why electrolux refrigerator model ei28bs56is5 temp hi
I understand your Electrolux refrigerator, model# EI28BS56IS5, is stating HI Temp. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and press the "mute sounds" button. After pressing the "mute sounds" button, press and hold the "Factory Default" button, for 5-10 seconds. You should see 37 degrees F displayed in the refrigerator display and 0 degrees F displayed in the freezer display. Give your refrigerator 24 hours to stabilize at these temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Refrigerators
I have two problems with my 2003 Electrolux refrigerator (model # FRS23H5ASB6). 1) We just replaced the water filter, but now the ice maker will not make ice. The lever is in the on/down...
There is no power up there - best you get a schematic for the unit so you can figure it out. The site enclosed often has schematics for this type of appliance. All you need is an ac voltmeter and you are ready to start checking. Search Over 2 1 Million Appliance Parts
Sep 05, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Fridge not working
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
Jan 03, 2009 | Amana ABB2224D Bottom Freezer Refrigerator
Complaint
I am contacting you on behalf of Electrolux Major Appliances in relation to your posting on www.fixya.com. I would like to apologize for the difficulty you have had with your appliance. I would appreciate the opportunity to discuss this issue with you so that I can personally look in to this matter in order to do so please send me your contact information, and the best time to contact you. I would also need your model and serial number and a file number if available, so that I can research this matter? Again I regret the disappointment with your appliance and look forward to resolving this issue with you.
Sincerely
Chris Polk
Escalation Specialist
chris.polk@electrolux.com
Aug 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
General Electric model # GSS25JSRFSS
if your appliance is humming then your motor might be out. Im not positive but i had a similar problem of the humming and clicking and the entire motor burned up. Might be a reason the lights are fading and such... Hope this helps
Jun 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
64 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
