Question about Remington R5130
I need assembly diagram & instruction for rotary/flex heads. Also, tiny springs for same. Thank you!
Kawasaki Rotary Tool is missing the square collet nut
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Oct 02, 2009 | kawasaki 840168 Green 150 Pc Rotary Tool...
Reassembling the Hitachi NR 83A2 (S) magazine
The reason that you are having trouble re-assembling the ribbon spring is that you need three hands to complete the job. As you recall the nail pusher just slips into the front of the rails. The pusher has the spring and a pin to retain the spool in place. Install the spring with the bolt hole towards leaver and slip into the front of rails. Take a small paper clip and bend a small hook to catch the ribbon spring. Hook the springs bolt hole with the paper clip and hold the spring in the approximate position for bolt as you push the assembly into rails and use latch to hold. While holding spring with paperclip, insert bolt thru rails and spring into nosepiece. Just break off the paperclip at this point and you are almost done. Some nailers have a metal support clip that you would need to have in place on bolt before installing bolt thru spring. For a breakdown of the gun go to www.toolpartsdirect.com. The other bolt for rails has a support/guide for the safety foot. Good luck and email if you have questions.
Apr 11, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Spring Horse
You can go to the Radio Flyer website and download the assembly instructions.
Jan 10, 2009 | Radio Flyer Liberty The Spring Horse By
Dremel Flex shaft attachment model 225
Dremel has an exchange program for the 225 Flex Shaft. Send your flex shaft and 17.90 and they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264 Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 09, 2008 | Dremel Variable - Speed Multipro Rotary...
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 02, 2008 | Dremel Variable - Speed Multipro Rotary...
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
Xerox phaser 8400
Replacing the pring head.
1. Remove the side covers.
2. Remove the ink loader assembly. There are 2 connectors on the ink loader. SO remove it slowly.
3. Remove the spring guides on the print head. One on each side, Held in my one torx screw.
4. Remove the spring bracked assembly on the left side of the printer, it puts pressure on the XY axis motor to position the print head. Just pop it off and position it up and to the left of the bracket.
5. Remove the steel square block on the left bottom side of the frame.
6. Unplug the harness and ribbon cables and then from the back of the printer, remove the print head, be careful not to hit the drum.
Install the print head, the ribbon cables are somewhat difficult to plug back in, Just be patient. and make sure they are conneted firmly. Also when replacing the cables and harness, be sure they are routed corectly so the print head does not get bound on them.
Set the print head into position and install the steel block, then the spring bracket on the XY motor, then the spring brackets in the proper positions. Dont forget to put that spring bracket back on, It is easy to over look.
Make sure all things are plugged in on the print head.
Next reinstall the ink loader, make sure all connectors are connected.
Install the covers and you are done.
Take your time, probably should take about an hour. Just to it carefully and methodically.
Nov 13, 2007 | Xerox Phaser 8400 Laser Printer
Remington R5130 Logo
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
