Question about LG WM2277H Front Load Washer
Washer is displaying OE have checked all the drainage and still doing it
    Sergeant:
  • 380 Answers
If you are handy with a meter, just the coil of the drain pump. Should be around 10-20 ohms. anything else, replace the pump. Try seeing if there is any kinks or bends or blockages in the hoses and pumps.
If all else fails. replace main board.
Posted on May 27, 2009
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
Getting OE error in my LG Tromm washer
Can be down to
kink in drainage hose
water drain pump
or an often overlooked drainage problem ...believ it or not can be a malfunctioning heater in the machine...
hope this points you in the right direction..
Apr 15, 2014 | Washing Machines
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
Water is not draining.... OE symbol appears on display. Checked the connection up to sink and drainage out to garbage disposal. everything seems fine there!
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter by removing the bottom front access panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jun 12, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | Washing Machines
When washing clothes my machine says oe and still has water in it
the OE flashing code means there is a drainage problem.
check hoses for Crimping or Clogging.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LG WASHER/DRYER
OE is a drainage error.
This can be anything from a plugged filter screen to a faulty drain pump.
The filter screen location and cleaning procedure can be found in your owner's manual or online at the LG website.
Aug 05, 2008 | LG WD-12126RD Front Load Washer / Dryer
OE blinking
Hi
I have the same machine and OE means drainage trouble.
  • Check clogging of water drain hose (or hose twist of freezing)
Cheers
Aug 01, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
OE Error
drainage issue check if anything blocking filter
Mar 08, 2008 | LG WM1812C Front Load Washer
LG WM2277H Front Load Washer Logo
218 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
