Question about Fujitsu Computers & Internet
00C08280: 0280: fan error has occurred
Fan not working with error code
I have just bought a laptop uh552 lifebook fujitsu. Upon start up, it says: Fan error has occured. By the way, it's about a time since I have heard a sound of fan, when working with it. Before that, fan had been making a clear sound. What should I do? Is there a real problem?
Posted on May 07, 2014
My panasonic Viera tc-p60gt30 has 11 blinking LED error code this TV does not have a fan. Could it be the power supply? Is there a place to plug in a fan to solve the error code?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 24, 2015 | Panasonic Televison & Video
Help error code upside down F E can you help
FE ERROR IS FAN MOTOR FOR DRYER HAS PROBLEM, TRY TO OPEN THE TOP COVER AND YOU WILL SEE HOW TO CHECK AND REMOVE THE FAN MOTOR TRY IT TO ROTATE BY YOUR HAND ND TESTING AGAIN(STOCK-UP) IF THE SAME PROBLEM STILL OCCUR CHECK THE VOLTAGE OF THE FAN MOTOR BASE ON HIS REQUIREMENT IF YOU KNOW HOW TO CHECK IT, IF THE VOLTAGE IS RIGHT YOU NEED TO REPLACED THE FAN MOTOR ASSY.
Mar 11, 2015 | Kenmore Front Load Washer
Flashing number 2 code
Remove batteries.
Insert a paperclip or similar object into the "reset" hole and hold in for 10+ seconds.
Insert new batteries.
This should reset the thermostat to factory settings and clear all programs, and it should work normally afterwards.
If the error occurs again within a month, then call Hunter tech support at 888-830-1326 between 7am - 7pm US Central timezone.
Oct 13, 2013 | Hunter Fan Company 5/1/1 Programmable...
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
HP 8100 dn error code of 57.5 comes up, power cycle down does not fix the problem
HP LASER PRINTER 8100, 8150 ERROR 57.5 code
1. The fan 1 or the laser/scanner fan has occurred.
2. Replace fan 1
3. Replace the D.C. controller board.
Try reseating the connector to the fan, it may have worked loose.
May 18, 2012 | HP LaserJet 8100dn Printer
I would like know the method for edit error of hp laserjet P3005n error 57.03. Please suggestion or method for edit to me Thank you .
Hello Niramon,
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified during device power up. Fan operation occurs only during power up or during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan. Verify that the fan is connected to connector J512 on the ECU PCA. You might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
Jun 13, 2011 | HP LaserJet P3005n Printer
HP 8150 error code of 57.5 comes up, I cycle power, I have checked all the cables and still comes up with error code. Does anyone have any suggestions?
Hi
Error code 57.5 in HP 8150 means that printer fan error has occurred with the power supply fan. This issue can also be due to laser/scanner fan. Make sure both the fans are working perfectly fine. If the fans are fine, then the error is due to DC controller board.
To resolve this error turn off the printer for 4-6 hours (atleast 4 hours), this will reset the error. However, even after 4 hours you still can see the error then please check and replace the fan1 (power supply fan). Also, check for any burnt components on the dc controller board.
Daniel Scott
Jun 18, 2010 | HP LaserJet 8150 Printer
Error code 57.3???
Fan number 3 (I don't have the manual on me or I would tell you exactly which fan that is) is either dirty or fried. OR it's the DC controller.
A temporary printer error has occured with one of the fans. That's the 57.XX error, the XX stands for which fan.
Clean and/or replace the fan first, and then the DC controller.
Apr 22, 2010 | HP LaserJet 9000n Printer
Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Jan 13, 2009 | Lexmark T642 Laser Printer
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
Computers & Internet Logo
1,235 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
