Question about GE 32GT740 32" TV
TV will not turn on just clicks as if it is going to and continues to click 5 or 6 times
2 Suggested Answers
  • 145 Answers
SOURCE: When lighting any burner...the igniter continues
My parts list doesn't tell me if that is an auto relight unit or not. But since you say it happens on any burner I'll leave out stuck ignitor switch for now.
Check the house ground wire to the unit and check that the burner caps are installed properly. The auto units read a ground when they ignite so if the burner caps are on wrong or dirty they can cause this.
jim
Posted on Jul 27, 2009
Clicking sound
thats an old set, its about time..
Oct 04, 2014 | Philips 42PFP5332D 42 in. Plasma...
Sony Trinitron color TV 36 inch
hello,
You should examine the input power of the TV. If you dare to open the back of the TV You should examine the by using the tester to test the continuity of the voltage input of the TV. i guess voltage regulator need to be tested.
Be careful high voltage inside the TV.
The best way is to contact the vendor of the TV or sony service center in your area.
may this help,
melnavz
May 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a philips remote control and I need the code to control a pioneer DVD player
Though all remotes are differnet just try this it can be kind of standard. But not all remotes are always compatible
1. On the remote control, press DVD once and Turn DVD player off
2. Press and hold SET until the red light blinks twice, then release SET.
3. Aim the remote control at the TV and press SCAN. The red light will blink twice.
4. Continue aiming the remote control and click on and off at the DVD Player (which may take up to 5 minutes) until it turns off. Immediately press any key except VOL-, SCAN, or SET. If SCAN is pressed again after any key stops Auto Scan, the remote will continue Auto Scan of the next ID from where it stopped. If you have passed by the code that turns off the TV, press VOL- one or more times until the TV turns on again.
5. To lock in the code and exit Auto Scan, press and release SET the red light will blink twice.
1. Or if you have a code. Press Set
2. Wait for blinks
3. Put in code.
4. Test it and if it works click set if not try next one.
Jul 17, 2011 | Philips Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I have a Samsung series 5 full HD LCD flat, brand ...
Is there a clicking sound? Unplug the power cord for 20 seconds and see if this helps reset the circuitry. If the clicking continues, go to http://www.fixya.com/support/t722954-samsung_lns4051_dx_makes_clicking. If you can see defective caps on the power board and don't feel comfortable replacing, parts can be ordered at PartStore.com.
May 21, 2010 | Samsung LN32A540 32 in. LCD HDTV
Clicking noise
The clicking noise is a protection circuit that prevents the TV from switching on when a fault is detected.
That means that there is a short, a bad solder joint, or a bad component inside the TV, usually any good technician is able to find out at least the nature of the fault. Often this jobs must be done at a repair shop, as testing may take time, probably your technician was just in a hurry.
All you can try at home is leaving tv unplugged for a couple of hours, this drains power from the set , and fix some problem.
If it does not work send it to a repair shop.
Dec 11, 2008 | Akai PT4298HD Rear Projection Television
50HP66 Plasma TV wont turn on fully. I hit the power button. It goes green for like 3-5 seconds then go back to red off light. It continues this untill I unplug the TV.
did you get your tv fixed? have same problem last night...a loud click and then blank screen and just tries to turn on, can you email at res116@comcast.net
May 18, 2008 | Toshiba Televison & Video
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sound Fades, then TV shuts off then continues to recycle on & off
Sometims several capacitors start going bad giving you the audio problem, but I don't remember the set turning itself off. That could be a secondary problem around the flyback transformer which may have a bad solder connection. I would check that first. Otherwise, I would be tempted to go with HDTV.
May 29, 2007 | RCA F36685 36" TV
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
