Mac Book boots up OK but then the Key board and Mouse are frozen. Have tried PRAM reset and all the rest but no good. Have even tried C key with my operating system disk but nothing
    Brigadier General:
  • 3,917 Answers
The best solution is a hard reboot.
Well one of the suggestion would be pressing down the num-lock button until it becomes alive again.
This thread definitely points to it being a Leopard problem. Many different hardware and upgrades to Leopard cause the problems. After 10.5.2, at least for me, the problem got worse.
Also somehow its also related to Parallels but if u are running VMWare then it looks like it’s Leopard doing it because it also happens if VMW isn’t running.
The last option is of course to Archive/Install.
You can also read THIS article (http://www.tuaw.com/2007/10/31/logitech-mouse-control-in-leopard/) and then un-installed all the Unsanity software, along with old version(s) of MicroSoft Mouse software. I then installed SteerMouse (http://plentycom.jp/en/steermouse/) and it seems to have solved my problems. You may want to check it out.
Thank You
Posted on May 19, 2009
How to fix the LG LCD LM270WQ1 (SD) (B3)?
Rarely, a Mac may encounter some peculiar issue during system boot that can cause quite a bit of panic, like booting to a completely black screen. It would be easy to interpret that as a potential hardware problem, and in some particularly rare situations that may be the case, but it's more often a software issue that can be resolved with some simple troubleshooting steps.
Case in point; one of our readers experience with his MacBook Pro, which out of the blue rebooted to a completely dark screen. Though it's rare, we figured this would be a good opportunity to share three potential solutions to this problem, and similar issues, should you encounter a dark screen on system start.
First, Reset the System Management Controller to Fix the Black Display on Boot
The first thing you'll want to do resolve nearly every power related issue on a Mac is to reset the SMC, or System Management Controller. This will dump and reset settings for anything power management related, and is long known to resolve problems with things like fans, heat, sleeping problems, and of course, display issues.
On any modern MacBook Pro or MacBook Air with a built-in battery, which is just a bout all of them nowadays, this is how you do that:
  1. Shut down the Mac and connect it to your MagSafe adapter and a wall outlet as usual
  2. Hold down the Shift+Control+Option+Power button at the same time for a few seconds
  3. Release all keys at the same time, then boot the Mac as usual
Older Macs can find directions here for the same process on their machines, it's slightly different if you can take out the battery.
When the Mac boots, hopefully the black screen has gone away and you're back to normal, but if it doesn't... reader Nathan D. wrote in with the next tip.
Second, Try a Keypress Sequence to Ditch the Black Screen
Regular readers may recall that we covered some OS X keyboard shortcuts for the Shutdown, Sleep, and Restart controls of just about every Mac, and this little key press sequence takes advantage of those. Oddly enough, it seems to work to resolve some of the mystery Mac booting into black screen issues. Here's the precise sequence to follow:
  1. Press the Power / OFF button once - this will bring up the dialog box which you can't see
  2. Press the "S" button - this is the shortcut to sleep the Mac
  3. Hold down the Power button until a hard shut down is forced
  4. Wait about 15 seconds, then hit the Power button again to turn it back on
This key press solution was discovered by reader Nathan D., who found it tucked away on MacRumors Forums, and it has worked for several other commenters there as well. Some other users on the MR forums suggest that resetting PRAM helped them too, but most power issues are resolved by the SMC reset.
Try a PRAM Reset to Resolve the Black Boot Display
If the above two tricks failed, a PRAM reset can often do the trick, as many of the commenters on this article can attest to. As a potential solution to the black screen on boot, this is done upon restarting the Mac similar to an SMC reset:
  1. Reboot the Mac and as soon as you hear the boot chime, hold down the Command+Option+P+R keys together
  2. When you hear the boot sound again, the PRAM has been reset so let the Mac boot again as usual
At this point your Mac should boot again as usual and no longer have the black display, loading Mac OS or Mac OS X as usual.
Finally; Enter Password, Hit Return
Some users in our comments report an interesting alternative finding if they hit the black screen on boot; if they enter their regular login password and hit the Enter/Return key, the Mac boots up as usual and they're good to go. Try this out, it might work for you:
  1. When the Mac boots into the black screen, enter the password you'd use to login to the Mac as usual
  2. Hit the Return key
If this works, you'll know rather quickly because the black screen will give way to the regular Mac OS desktop.
Did one of these solutions work to get past the black screen on Mac boot for you? If you happen to run into this unusual issue with your Mac, let us know how you resolved it, and if the above tips worked for your MacBook, MacBook Pro, MacBook Air, and whichever Pro or Air model it may be. If you still need any assistance call me on +1(518)348-9393 i will be glad to assist you
Aug 14, 2017 | Apple Computers & Internet
Mb324ll/a white screen
1.Try a Safe Boot
Mac OS X 10.2 and later Safe Boot includes disk checking and repair. First start your Mac in Safe Mode. To do this, shut down your Mac. Now Turn on your computer by pressing the power key while holding down the Shift key. When you see the Apple logo, release the Shift key. After your Mac fully starts, restart your computer normally without holding any keys/buttons during startup. Note that Safe Boot is slower to boot.
2.Run Disk Utility
Turn your Mac off by holding down the power button for a few seconds. Turn on your Mac and hold down the Command and R keys until you see the Apple logo. Then you should see a "Mac OS X Utilities" window. Select Disk Utility, click your OS X hard drive and select verify/repair disk.
3.Reset PRAM
This may fix your boot failure. PRAM ("parameter random-access memory") stores some of your settings. You may reset PRAM. To do that, turn off your Mac. Now turn on your Mac. Then, immediately, hold down the Option-Command-P-R keys until your Mac restarts. When your Mac is starting up, release the keys.
4.Reinstall Mac OS X
If nothing above works, you may try this. Your Mac needs to be connected to the Internet. See number#2 above. Follow the same steps. Restart your Mac and hold down the Command key and the R key until the Apple icon appears; when you see the Mac OS X utilities window, select the Reinstall option.
Mar 13, 2014 | Apple iMac A1224 20" Core2Duo 2.66GHz 2GB...
My imac does not start white screen with a ? mark
reset pram,
try holding down s key to boot in safe mode,
try holding down option key on startup and select drive,
install system disk and restart holding down c key.
Feb 09, 2014 | Apple iMac G4 Desktop
Restart appears on start up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Turn off mute mac
Just reset PRAM on the mac and try , turn off mac , then turn it on and immediately press option commant P and R key , keep holding it until your computer restarts and you will hear the chime and your volume is fixed
Oct 02, 2013 | Computers & Internet
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jun 06, 2012 | Apple MacBook Air
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
May 22, 2012 | Apple MacBook Air
IMac 10.4.11 all of a sudden only boots in safe mode
try resetting the SMC and the NVRAM. This occasionally stores the startup state and any keystrokes used during boot. Common issue with all intel macs. Resetting PRAM and NVRAM 1. Shut down the computer. 2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4. 3. Turn on the computer. 4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears. 5. Hold the keys down until the computer restarts and you hear the startup sound for the second time. 6. Release the keys. Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models. To reset the SMC on an iMac 1. From the Apple menu, choose Shut Down (or if the computer is not responding, hold the power button for approximately ten seconds until it powers off). 2. Unplug all cables from the computer, including the power cord. 3. Wait at least 15 seconds. The SMC reset occurs automatically once the iMac has been unplugged from the AC power source for several seconds. 4. Plug the power cord back in, making sure the power button is not being pressed at the time. 5. Reconnect your keyboard and mouse to the computer. 6. Press the power button on the back to start up your computer. Note: The iMac does not have a button on the main logic board for resetting the SMC, which eliminates the need to remove the computer?s cover to reset it (as required for some other models).
Jun 10, 2009 | Apple Mac OS X 10.4
When turning on my macbook pro
Please clean-up the RAM modules wiping it with a dry cloth and re-insert it back into its slot .
May 06, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
