Question about Brookstone Grill Alert Talking Remote Meat Thermometer
Will not read current temputure - Brookstone Grill Alert Talking Remote Meat Thermometer
Temputure gauge fluctuates when car is at operating temputure
The radiator might have "air pockets". They cause erratic readings at the temperature gauge. Check the system to see if bleeder valves are provided. If they exist, just open the valves allowing air out of the system while filling with coolant until coolant drips from the bleeders. If bleeder valves are not provided, open radiator cap and fill with coolant. Start the engine for about 30 seconds, check coolant level and fill to level if necesary.
Nov 11, 2013 | 1999 Mercury Grand Marquis
P temputure sensor
front panel bumper area ,,,if you are getting an unusually low reading its possible the sensor has fell off and all you will be looking for are a twin wire plug ,,,, the ecu assumes a default temp in the event of the sensor becoming damaged or lost due to its position
Feb 11, 2012 | 2005 BMW M3
When you come to a stop sign and set a while the temputure gage will go one or two lines past mormal. when you are driving down the road ihe temputure gage shows mormal
if its very hot out then this can be normal.make sure the cooling fans are working properly.it could be a thermostat that is not working properly,make sure the coolant level is full.if there is only say 2 lines then the hot line then you could have a head gasket that is just starting to go bad.
Jun 14, 2011 | 2002 Chevrolet Impala
Temputure gauge reading low and i have no heat
I would check antifreeze level. if low it wont have enough antifreeze to produce any heat. Maybe partially froze. If so warm up car with heater enough to drain antifreeze and replace making sure you have the right mixture of antifreeze and water for cold wheather. they sell a gauge for pretty cheap that can tell u what your mixture in your car is.
Dec 16, 2010 | 2004 Chevrolet Cavalier
My 1999 old's alero temputure gauge read's hot radiator taking on water a galon every 15 miute's no leak's
It's leaking then. You just can see where. Check for steam out of the exhaust pipe. You might have head gasket or head warpage issues. Also check the engine oil. Does it look like coffee with creamer in it? Those are a couple of possible internal coolant leak points. If this doesn't yeild anything, you need to have the cooling system pressure tested and you will find the leak.
Sep 23, 2010 | 1999 Oldsmobile Alero
Coolant Temputure below thermostat regulating temputure
you need to replace the thermostat with a new one,
replace it with a 190 degree one
Dec 20, 2009 | 2004 Buick Regal
Temputure and oil change
either you have a bad wiring prolem or you need new gadges
May 31, 2009 | 1997 Cadillac DeVille
Low engine oil in 1982 Maxim 750. Don't know what type to put in?
depends where you live
ambiant temputure
10w-40 in very warm climate
read about motor oil
Apr 10, 2009 | 1985 Yamaha XJ 700 X Maxim
TEMPUTURE SENSOR BLEW OUT
yes have replaced several plastic intakes due to coolant and vacuum leakage not a recall.
Dec 07, 2008 | 2001 Ford Crown Victoria
Brookstone Grill Alert Talking Remote Meat Thermometer Logo
107 people viewed this question
Top Brookstone Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Brookstone Grilling Expert? Answer questions, earn points and help others
