Question about HP Computers & Internet
I3 cpu n1996 - HP Computers & Internet
Change processor
it is unlikely but without more detailed information on what computer / CPU / motherboard you have no-one can say for sure
Jan 29, 2014 | Computers & Internet
Can a Intel Core I3 be installed in a Emachines D725
No. Not the one listed above (socket LGA 1156) You need to look for a mobile CPU (possibly mobile 479). They differ physically and architecturally. Even then you need to establish that the CPU is removable and verify BIOS has support for upgraded chip. Talk to your local repair shop for finale decision.
Nov 23, 2012 | Intel Core i3 530 293 GHz processor
No display in MSI N1996
central processing unit CPU
as it says it processes all information that runs a computer
hope this helps
Jun 19, 2012 | MSI Computers & Internet
Dell 4050 i3 laptop only give 3 beep no display
dear
3beeps almost means cpu failure
you can try to reflashing bios if not you must replace cpu itself
Apr 07, 2012 | Dell Computers & Internet
Which is the perfect OS x86 or x64 for intel core i3 cpu 530 @ 293 ghz
The i3 cpu is a 64 bit processor, therefore it will suit 64 bit Windows OS.
Jan 29, 2012 | Intel Core i3 530 293 GHz processor
Sir please tel me which motherboard is compatable for i3 530 & i3 540 processors
Hi Mate,
You are looking for motherboards that are either pin 1156 or 1155 please see the links below, mainly most 1155 are compatible with the above, 1156 are compatible but then some only support i5 and i7, when you see a 1155/1156 pin board make sure you check on the hardware manufactures website for specifications as most of them actually "TEST" most CPU's for quality assurance purposes and will have a spreadsheet which tells you if i3 530 & i3 540 is compatible. for ex: http://www.asus.com.au/product.aspx?P_ID=qWmZUAdNKeozTOXb&templete=2 as you can see asus have a CPU support section and specifies your cpu's and if they will work.
http://www.msy.com.au/default.jsp?category=215
http://www.msy.com.au/default.jsp?category=156
hope this has been of help.
Kind regards,
Oliver.M
Jan 24, 2011 | Computers & Internet
No power on N1996 argon motherboard. Cpu fans
if it's switching its self off after about 10 second then Your CPU Chip is not right some how it could be / damaged / the wrong socket type for the board as alot of CPU's are very simmler / The CPU's (4 pin) power supply is not connected or the CPU hasent gone in to the socket properly when this happens it will power up but will send no power to the monitor, or somtimes set off an alarm that sounds like a sciron going off.
May 05, 2010 | HP Compaq Motherboard
Mercury n1996.......AGP slot or PCI????
n1996 is NOT the model number. ALL MSI boards are labeled n1996 - it's their C-Tick number. You need to find the actual model number which should be listed on a sticker near the main CPU socket. Search for that on msi's website.
Let me know what the model # is..
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Apr 27, 2009 | Computers & Internet
Heat on n1996
you may need to clean the heat sink, fan, and the processor.... put some silicon wax between the heat sink and in the processor.. ^^
Jan 30, 2009 | Acer AOpen MX 3ZA (91.88110.101)...
Pin configuration for front panel on n1996 motherboard
Aug 18, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
