Question about Acer S202HL LCD Monitor
Monitor won't turn on
It was working just fine, then I left the room to make a sandwich, and when I came back the monitor was out. The power supply has a green led showing. But I can't tell if I'm getting power or anything. It's like it's dead. Thoughts?
noone
  • 105 Answers
SOURCE: Stopped working suddenly after 18 months daily use
It appears either the inverter supply board or the main video board have failed. First replace the inverter board, if not fixed, replace the video board. Mike
Posted on Aug 09, 2006
  • 89 Answers
SOURCE: Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Posted on Apr 29, 2008
bammbammfran
  • 159 Answers
SOURCE: RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
Fix-4U
  • 293 Answers
SOURCE: monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Posted on Oct 17, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
The power button on my computer won't turn on the computer
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
Nov 25, 2012 | eMachines EL133105 Desktop Computer with...
Won't turn on
if no any light indicator at the front panel of the monitor, the cause would be power supply failure. to do the check up, you must need to remove the back cover. the power supply board it was connected the power cord. look for a blown fuse and a bulging electrolytic capacitors at the power supply board.replaced those bulged capacitors, you can find at www.digikey.com for parts replacement.
Nov 17, 2012 | ViewSonic VX2255 Monitor
Iiyama E2607WS just stopped working - completely dead - internal fuse OK
In most cases there are one or two capacitors in the power supply that open, and in some situations they have a bulge at the top making it easier to spot.
Apr 19, 2012 | iiyama E2607WS 26 inch Monitor
LG Monitor won't turn on
I had this same problem with mine, and had to replace it. Sometimes it's the power supply, but depending on how old it is and how much it's been used, usually unlikely.
If you have a way to check the power supply output for proper current and voltage, and it appears to be fine then that's eliminated as a possibility.
Typically, time to replace it, unfortunately.
I hope this helps!
Feb 13, 2012 | LG Computers & Internet
No power working fine walk out of room come back
If you want to repair, you will have to take it apart. The fault is the power supply. after you take it apart look for cap with the tops bluging. if you want post an picture of the power supply board..
Feb 23, 2010 | Proview Computers & Internet
Computer turning on?
When you say power supply, I assume you mean the power cable plugging the tower into your wall socket. It sounds like your actual power supply inside the tower itself has died. You will have to replace the power supply itself, it is too dangerous to try and repair a power supply, even for an experienced technician. You can find power supplies for pretty cheap online and at PC resellers, and usually a service tech to install for you, if you don't feel comfortable installing yourself.
Before you go this route, make sure you test another outlet as well.
Dec 28, 2008 | HP Pavilion a320n PC Desktop
Television won't turn on
Sounds like a power supply problem, you'll have to take it to a repair shop to fix that unless you know electronics. Good luck.
Nov 15, 2008 | Philips Magnavox 27MS343S 27" TV
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Acer S202HL LCD Monitor Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
