Question about VIPER 7141V VIPER 4BUTTON REMOTE 7141V
Which buttons need to be pressed to turn on the rear defrost on a viper 7141v remote
2 Suggested Answers
logosc75
  • 625 Answers
SOURCE: I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Posted on Aug 26, 2012
How to program a ezsdei474 remote to a viper 130xv
Open door, turn on ignition. Press and release valet switch then, press and hold valet switch. Press lock button on remote. Release valet switch, turn off ignition. Test.
Feb 08, 2014 | 473v Viper Remote Case Three Button
Program remote
get in vehicle turn key on with new key fob in car, let run for 20 or so then turn off . hit the unlock button it should be programmed but not promising anything lol
Sep 30, 2013 | VIPER 7141V VIPER 4BUTTON REMOTE 7141V
Will not lock or unlock doors
Does the unit respond when you press the unlock button, i.e., two chirps from the siren and/or parking lights flashing? If so, then the door lock wires are no longer connected or, there is an issue with the vehicle's door lock actuators.
If the Viper system does not respond with the above mentioned sounds and lights, then the remote is not programmed to system.
To program: turn the ignition on, press and release the valet switch one time then, press and hold the valet switch. While holding the switch, press the lock button on the remote. The system should respond with a long chirp from the siren.
Sep 07, 2012 | 7141V 4Button Remote
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Aug 21, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How do we know when the battery of the remote needs to be changed
The best way is to notice the distance at which the remote will work. Also if you use the reomote often it would be good to change at least once every three months.
Jun 12, 2010 | Viper 7141V 4Button Remote
Would like to know what the bottom 2 buttons mean on Viper 7153v
the bottom button is for function shift, and is used (with aux button) to activate certain functions (add on optional features like trunk pop, window roll up/down, rear defroster, etc--all depend on car and install) or by itself for status updates (interior temp check-press once, release, press and hold; remaining runtime-press and release three times, press and hold; lock status-press and release twice, press and hold). it is also used with lock and unlock for silent arm/disarm, and also to enter valet mode.
Feb 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Jul 11, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
VIPER 7141V VIPER 4BUTTON REMOTE  7141V Logo
23 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
