Question about Philips 43P8341 43" Rear Projection Television
After pushing the on button,switch lights up, then set make's
I push the button on the front of the set,..it lights up but then a high pitch buzzing accures,and repeats itself over, and over,light on the front ...then it shuts off, and the light on the front of the button blinks on, and off....thank you for your time..
jomaru
  • 337 Answers
SOURCE: Power up then off, no picture, blinking red LED
The high voltage does come up but the set goes into shutdown because is sensing a problem somewhere in the set,the shutdown circuit gets activated when the high voltage is too high, a problem in the horizontal deflection circuit or because there is a problem in the secondary of the output transformer,this transformer helps develop voltages supplies and if one is missing the set senses the problem and shutsdown,there is another possibility and is related to the picture tube,there is a resistor in the crt board ,it should measure 51 ohms only ,sometimes it opens up and gives you same symptom.If you are familiar with tv service you can check this resistor and be alert of the other possibilities,if you are not too familiar be safe and get assistance from a servicer. Let Us know how it goes,or if you need more information.
Posted on Oct 26, 2006
SOURCE: TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Posted on Jun 25, 2007
Kazong
  • 152 Answers
SOURCE: assistant
check your sleep timer settings thats the most comman prob
Posted on Dec 18, 2007
SOURCE: Power light on but no picture
I've got the same problem. No sound, no picture, just a green light. The light comes on when its plugged back in. No buttons work. Occasionally the light flashes off.
Posted on May 30, 2008
bobjrdns
  • 84 Answers
SOURCE: tv wont turn on
your tv is in shutdown mode replacing the power suply module may corect this problem
Posted on Oct 18, 2008
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Tip
Dryer when start switch pressed no start but buzzes
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
on Mar 01, 2015 | Dryers
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Philips 43P8341 43" Rear Projection Television Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
