Nokia N95 Cellular Phone
Problem for Nokia N95 Cellular Phone
Nokia n95 Phone memory full
By Rohan123 on Oct 18, 2007
Hi ive tried basicall everything. deleted everything from the phone and even restored factory setting but it still says memory full. Any ideas on how to fix this?
Comments:
Oct 18, 2007
- How do you do hardware reset? and what do yu mean take the back up of data *7370#?
Same Problem
May 01, 2009
-   I'm having the same prob,
General: Memory Full, close some applications n try again
cleared all the memory, phone n SD card NO USE
did a factory reset NO USE
tries every thing possible in my mind NO USE
still searching for the solution
some body told me i got to get the software reinstalled from the repair shop
-   stallion78
Apr 14, 2009
-   what is the pascode for n95 8gb for factory setting-   Guest
Mar 29, 2009
-   in my n95 ders memory full problem... i deleted all msgs but ther is same masage displayed... can u plz tell me wat should i do????-   ishhh
Jan 11, 2009
-   mem full will call but no sms-   Guest
Dec 03, 2008
-   not any problem, i jus want to know how to connect on my nokia phone memory istead of the memory card, ihave a n95 8gb -   kermz
Best Solution
posted on Jan 04, 2008
Helpful)
tamburrini
Rank: Apprentice
Rating: 89%, 29 votes
Backup all contacts and any files that you don't want to lose onto the memory card and then type *#7370# into your phone. Do not restore any data from PC Suite as this will bring back the problem.
I tried the above and it fixed the problem!
Comments:
Jan 04, 2008
- Backup all contacts and any files that you don't want to lose onto the memory card and then type *#7780# into your phone. Do not restore any data from PC Suite as this will bring back the problem.
Entered wrong code above!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on May 15, 2008
Helpful)
aklb1990
Rank: Apprentice
Rating: 92%, 10 votes
star hash 7370 hash. it really works. it will ask u to reset everythin, say yes. the lock code is 12345. enjoy ppl
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on Jan 30, 2008
Helpful)
MemoryFull
Rank: Apprentice
Rating: 86%, 3 votes
I tried all of the above...
Resetting...
Removing a lot of data (I now have only about 6000 contacts and 1000 memos)...
Upgrading the firmware...
and it still says "memory full"...
I am a bit desperate... I have spent over 10 hours on this...
any help? THank you
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Oct 18, 2007
Somewhat Helpful)
gizmo1
Rank: Wiz  Nokia Expert
Rating: 80%, 686 votes
Hi,Do hardreset but before do that Take the back up of Data *7370#
Gizmo1
Was this helpful?
Yes
No
Solution #5
posted on May 04, 2009
Very Helpful)
stallion78
Rank: Apprentice
Rating: 100%, 1 votes
<star> <Hash> <7370> <hash>
does work, i've a prob with my hash key on my laptop hope every1 can under stand the symbol which represents a number, right bottom button
but MOST IMPORTANT
do keep a backup either on ur computer or ur memory card. u can have ur back up on memory card by going into tools>memory>options>backup phone memory
it will create back up of all except ur calender enteries
take care of ur data on phone
rest this code will take care of the problem that so many of u r facing
i did all the heck that every1 else has narated here. every thing failed except this
* <hash> 7370 <hash>
Was this helpful?
Yes
No
Solution #6
posted on Mar 25, 2009
Very Helpful)
babm1
Rank: Apprentice
Rating: 98%, 20 votes
Hi there:
For months I've been searching on the Internet looking for a solution to my problem for my Nokia N95
It kept on saying that my phone memory was low and every time i deleted stuff (Including apps) the memory kept on eating away at its self with none of the memory that was there nowehere to be seen.
Save all your contacts and stuff you cherish on ur phone memory before u do this !!!!!!!!!!!!!!!!
I tried the factory reset ( *#7370# ) and the software reset ( *#7780# ) entered the code "12345" after each one and they both reset.... entered my country, date, time etc.... but it never sorted out my memory problems
Another reset is the 3 button reset... this worked on my phone and thank F**k it has :-)
what you do is switch off your n95 turn it back on but keep ur fingers pressed on the:
The star button ( * )
The number three button ( 3 )
And the Green button ( one you start to make phone call with )
did the same with the country date time and brill 140 Mb's free memory yee haaaaaaaaa
Was this helpful?
Yes
No
18 people thought this was helpful
Solution #7
posted on May 26, 2009
Very Helpful)
Machipucha
Rank: Apprentice
Rating: 96%, 12 votes
Ok people the solution is here. if you got Free up the *ucking memory Error like me. Do the following It Works 1000000% To Reset your Nokia N95 do this:
1.Turn Off Your Damn Phone 2.Unplug Your Damn Charge-cable(Won't Work intill it's on charge) 3. Use three button combination: *Press and Hold the Green Button (SendButton) *Press and Hold button number (3) *Press and hold(*) button By holding the Send/3/* buttons combination just turn ON your Phone somehow with your fourth finger! :-) Keep pressing The Send/3/* buttons combination Untill Your Phone Starts up With The COUNTRY SELECTION Choose your Country, Date, and time and Wualla. You Got 140 megabyte free. I Fixed it my self just a few Seconds Away. Thanks For the help Guys. It really Works. Don't Use The Codes use the Three button vombination, and don't forget to unplug the charge cable before a three button trick. It really works believe me!
Was this helpful?
Yes
No
10 people thought this was helpful
Solution #8
posted on Dec 27, 2007
Helpful)
todge
Rank: Apprentice
Rating: 88%, 2 votes
press & hold applications button the one to the left of the square one. close applications & try again
Was this helpful?
Yes
No
Solution #9
posted on Oct 22, 2009
Not Rated)
rlabhi
Rank: Apprentice
Rating: 0%, 0 votes
tnks.... I also had the same problem of full phone memory...
I did *#7370# it works but not get my phone mem fully back... gets a little free memory..
then i off the phone and then on...
while start up hold green button + * + 3 simultaneously....
I regained my phone memory back ....
thanks a lot.....
Was this helpful?
Yes
No
Solution #10
posted on May 03, 2009
Not Rated)
ideay
Rank: Master
Rating: 95%, 28 votes
Having problem with Nokia N95? Don't Worry. There is a site where you can easily fix your problem.
Mainly Nokia N95 problem is for Unlock CodePuk Code and other Lock Codes. If you are searching for such codes you Must Click Here.
There are also some problem with Nokia N95. Such as software problemhardware problem etc. If you having these problem you can Click Here. May you find your solution.
Was this helpful?
Yes
No
Solution #11
posted on Apr 27, 2009
Not Rated)
dessrd
Rank: Master
Rating: 95%, 21 votes
FIND YOUR SOLUTION FROM NOKIA.
HERE IS YOUR SOLUTION
www.nokia.com/n95/prob234ei32/solution
Was this helpful?
Yes
No
Solution #12
posted on Aug 06, 2008
Not Rated)
AstigZ
Rank: Apprentice
Rating: 0%, 0 votes
update the firmware of the phone.. get the latest version..
my phone version is now V20.0.015.
Was this helpful?
Yes
No
Solution #13
posted on Jul 31, 2008
Not Rated)
macosevilla1
Rank: Apprentice
Rating: 0%, 0 votes
typing *#7370# and *#7780# didn't fixed my phone!!
anymore suggestions! please! help!
Was this helpful?
Yes
No
Solution #14
posted on Jul 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i did the *#7780# thing
seemed to work
but then i went onto messages
& the stupid thing froze
can't turn it off
i have no idea how to get the battery out
i've only had it for a few months, my dad is going to kill me!
now its just the blue screen with the bubbles (O2)
& it shows the signal & battery..
but it wont do ANYTHING.
helpppp!
Solution #15
posted on May 27, 2008
Not Rated)
cutchy
Rank: Apprentice
Rating: 0%, 0 votes
i had the same problem and i removed the memory card, restarted the phone and it worked fine
Was this helpful?
Yes
No
Solution #16
posted on Jan 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it say enter lock code what is that
Popular Solutions for Nokia N95 Cellular Phone
Questions and Unsolved Problems for Nokia N95 Cellular Phone
Do you recommend Nokia N95 Cellular Phone?
Answer
Answer
nokia n95 will receive texts but will not send them
Answer
my n70 not work properly when i make any call music player is automatic on and 0 and 4 key will... (More)
Answer
wat will i doif my phone n95 8gb cnt be open?
Answer
i lost my sim card 2gether with my mxit pin please help???
Answer
hi my n955 wont send messages anymore it was sending them fine the othere day then it jus stopped... (More)
17 Other Users Have The Same Problem - Continued
Comment by mayankkindra, posted on Oct 24, 2008
hey my n95 is displayin ph memory full... i deleted all data frm ph memory.. bt after smtym it again displayed ph memory full... den i restored factory settings after dat ph ws workin properly bt after 2 dayz it again showd full memory delete some data... bt i m nt havin ny data in phone memory... i hd discovered dat wen i recieve or make call slowly n slowly phone memory gets occupied... plz help me .. m fed up wid dis...
Comment by mhaleyeg, posted on Aug 05, 2008
I am unable to access any accessories or programs as my n95 says the memory is full and to close applications. However, I am unable to get to any of the programs. And, how do I back up information if I can't get to it?
mhaleyeg@yahoo.com
Comment by mlancaster1, posted on Jul 22, 2008
nokia n95 memory full. wont send texts. memory been cleared
Comment by rinae, posted on Jul 01, 2008
same as Rohan
Comment by Guest, posted on Jul 01, 2008
It worked for me - thanks so much 02 couldnt help and said I had to send it in for repair!!
Comment by Guest, posted on Jun 28, 2008
Me too havin the same problem, its sayim memory low. do somethin
Comment by Guest, posted on Mar 27, 2008
the factory restore doesn't help!
Comment by me5214, posted on Jan 24, 2008
Exactly the same problem and message....
Hard Reset worked for me.
Comment by Guest, posted on Dec 26, 2007
i could not send messages as like ...notification phone memory full?
help.needed.
Comment by Guest, posted on Dec 11, 2007
I have exactly this problem... Please can some one help!! Its so annoying
Comment by Guest, posted on Dec 10, 2007
did u get the solution to the messaging issue?
Comment by Roobs, posted on Dec 10, 2007
Hi my N95 wont send text's !! I've spoken to o2 and they sent me a new sim but it han't made any difference ! when the message fails it says "General: Memory full. Close some applications and try again.". I have deleted as many messages as possible but o2 are useless can you help ?? please.
Regards
Rob
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nokia N95 Cellular Phone:
Top Cellular Phone Experts
Rank: Wiz Wiz
Solutions: 556
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
