Question about Panasonic TNPA5335BJ SC Board
Board problem tnpa5335 - Panasonic TNPA5335BJ SC Board
How to Add a Board on the MA5600?
You can add a board on Huawei MA5600 in the following two ways:
· Adding a board offline: Run the board add command to add a board to an vacant slot (in this case, the system generates the "Board Fault" alarm). Then, insert a board to the slot (in this case, if the type of the inserted board is the same as the type of the board added offline, the system generates the "Board Recovery" alarm; if the type of the inserted board is different from the type of the board added offline, the system generates the "Type Mismatch" alarm).
· Automatically discovering a board: Insert a board to an vacant slot (in this case, the system displays a message indicating that a board is automatically discovered, and the board is in the auto-find state). Then, run the board confirmcommand to confirm the board that is automatically discovered.
This way is also can be adopted by Huawei MA5616 equipment.
Apr 27, 2017 | The Computers & Internet
Is There Any Changes in the Board Software Version After a Service Board Is Replaced?
fter a service board is replaced, the control board checks and determines the software of the new service board.
1. If the IO board package file contains the new service board, the control board updates the software of the new service board to that of its own.
If the new service board supports the anti-downgrade function and the control board software is within the anti-downgrade version range, the new service board runs with its default software.
If the new service board supports the anti-downgrade function but the control board software is not within the anti-downgrade version range, the control board updates the software of the new service board as that of its own.
If the IO board package file does not contain the new service board, the software of the new service board is loaded to the IO board package file of the control board.
Huawei GPBD Board Thunder link com
Dec 09, 2016 | Televison & Video
Vizio LC470DUG powers on for 4 seconds than goes off--possible mother board
No such thing as a mother board in a TV set. Here is a list of the PCBs
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it may be time to start testing different boards to see if they are functioning properly.
Main Board
The main board, or motherboard, is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. This part is also sometimes called the main module or the A/V (audiovisual) board.
Power Supply Board
Another large and important board inside a television is the power supply board. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long, thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T-CON board, is typically only found on LCD and LED TVs. Plasma TVs, on the other hand, use a logic board. The functions of the logic and T-CON board are similar: each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixilation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and Y-sustain boards only appear in plasma screen TVs. The X-sustain board may also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The X-sustain board activates all the display lines at once, while the Y-sustain board addresses all the individual lines of display. When one board breaks down, it probably does not affect the functionality of the other. However, it may be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short lifespan anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
Buffer boards are also only found in plasma screen TVs. Connected to the Y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
Dec 03, 2016 | Vizio Televison & Video
What boards are applicable on OSN7500?
List of Cross-Connect Boards and System Control Boards T1PSXCSA,T2PSXCSA Super dual-plane cross-connect and synchronous timing board N4GSCC,N6GSCC System Control and Communication Board List of Packet Processing Boards N1PEX2 2-port 10 Gigabit Ethernet switching processing board N2PEX1 1x10GE Ethernet processing board N1PEG8 8-port Gigabit Ethernet switching processing board List of http://www.thunder-link.com/HUAWEI-OPTIX-OSN7500_p554.htmlPacket Interface Boards N1CQ1 4-port channelized STM-1 CES optical interface board N1PEFF8 8-port FE optical interface board N1PETF8 8xFE electrical interface board N1MD12 Multi-protocol 32xE1 interface board (120 ohms) N1MD75 Multi-protocol 32xE1 interface board (75 ohms) List of EoD Boards N1EDQ41
4-port 622/155 Mbit/s SDH optical interface Ethernet dual-mode multi-function processing board List of SDH boards N4SLD64> 2xSTM-64 optical
interface board N1SLD64 2xSTM-64 optical interface board N4SFD64 2xSTM-64 optical interface board with
the FEC function T2SL64, T2SL64A 1xSTM-64 optical interface board N1SF64, N1SF64A,
N4SF64 1xSTM-64 optical interface board
(with the forward error correction
(FEC) function) N1SL64 1xSTM-64 optical interface board N4SL64 1xSTM-64 optical interface board N4SLO16 8xSTM-16 optical interface board N1SLO16 8xSTM-16 optical interface board N4SLQ16 4xSTM-16 optical interface board N1SLQ16, N2SLQ16 4xSTM-16 optical interface board N3SL16, N3SL16A 1xSTM-16 optical interface board N1SL16, N1SL16A,
N2SL16, N2SL16A 1xSTM-16 optical interface board N1SF16 1xSTM-16 optical interface board
(with the outband FEC function) N1SF16E 1xSTM-16 optical interface board
(with the outband EFEC function) N3SLH41 16xSTM-4/STM-1 optical interface board N3SLQ41 4xSTM-4/STM-1 optical interface board N1SLQ4, N2SLQ4 4xSTM-4 optical interface board N1SLQ4A 4xSTM-4 optical interface board N1SLD4, N2SLD4,
N1SLD4A 2xSTM-4 optical interface board N1SL4, N2SL4,
N1SL4A 1xSTM-4 optical interface board N1SLH1 16xSTM-1 signal processing board N1SLT1 12xSTM-1 optical interface board N1EU08 8xSTM-1 electrical interface board N1OU08 8xSTM-1 optical/electrical
interface board (LC) N2OU08 8xSTM-1 optical interface board (SC) N2SLO1, N3SLO1 8xSTM-1 optical interface board N1SLQ1, N2SLQ1 4xSTM-1 optical interface board N1SLQ1A 4xSTM-1 optical interface board N1SEP1 2xSTM-1 line processing board when interfaces
are available on the front panel
8xSTM-1 line processing board when interfaces are
available on the corresponding interface board N1SL1, N2SL1,
N1SL1A 1xSTM-1 optical interface board List of PDH board N2SPQ4 4xE4/STM-1 electrical processing board N1MU04 4xE4/STM-1 electrical interface board N2PQ3 12xE3/T3 service processing board N1D34S 6xE3/T3 electrical switching interface board N1C34S 3xE3/T3 electrical switching interface board N1PD3, N2PD3 6xE3/T3 service processing board N1PL3, N2PL3 3xE3/T3 service processing board N1PL3A, N2PL3A 3xE3/T3 service processing board
(Interfaces are available on the front panel.) N1PQ1 63xE1 service processing board N2PQ1 63xE1 service processing board N1PQM 63xE1/T1 service processing board N1D12B 32xE1/T1 electrical switching interface board N1D12S 32xE1/T1 electrical switching
interface board (120 ohms) N1D75S 32xE1 electrical switching
interface board (75 ohms) N1PFL1 8xE1 optical processing board N1TSB8 8-port electrical switching interface board N1DX1 DDN service accessing and converging board N3DX1 DDN service accessing and converging board N1DXA DDN service converging and processing board N1DM12 DDN service interface board List of EoS boards N1EFT8 8xFE/16xFE transparent transmission board N2EFT8 8xFE/16xFE transparent transmission board N1EFT8A 8xFE transparent transmission board N2EFT8A 8xFE transparent transmission board N1EFS0A 16xFE switching and processing board N2EFS0, N4EFS0,
N5EFS0 8xFE switching and processing board N1EFS4, N2EFS4,
N3EFS4 4xFE switching and processing board N1EAS2 2x10GE Layer 2 switching and
processing board N3EAS2 2x10GE Layer 2 switching and
processing board N1EGSH 16xGE switching and processing board N1EMS4 4xGE and 16xFE switching and
processing board N1EMS2 2xGE and 16xFE switching and
processing board N1EGS4, N3EGS4 4xGE switching and processing board N1EGT2, N2EGT2 2xGE transparent transmission board N2EGS2, N3EGS2 2xGE switching and processing board N1EFF8 8x100M Ethernet optical interface board N1EFF8A 8x100M Ethernet optical interface board N1ETF8 8x100M Ethernet twisted-pair interface board N1ETF8A 8x100M Ethernet twisted-pair interface board N1ETS8 8x10/100M Ethernet twisted pair
interface switching board List of ATM boards N1ADL4, N1IDL4 1xSTM-4 ATM service processing board N1ADQ1, N1IDQ1 4xSTM-1 ATM service processing board List of RPR boards N2EGR2 2xGE ring processing board N2EMR0 12xFE and 1xGE ring processing board List of SAN/Video Boards N1VST4 4-port video service transparent
transmission board N1MST4 4-port multi-service transparent transmission board List of Auxiliary Boards T1EOW Orderwire processing board T1AUX System auxiliary interface board N1FANA Fan board (high power) Lost of WDM board TN11CMR2 2-channel optical add/drop multiplexing board N1CMD2 2-channel bidirectional optical multiplexer and demultiplexer board TN11CMR4 4-channel optical add/drop multiplexing board N1MR2C 2-channel optical add/drop multiplexing board TN11MR2 2-channel optical add/drop multiplexing board N1LWX Arbitrary bit rate wavelength conversion board TN11MR4 4-channel optical add/drop multiplexing board N1FIB Filter isolating board N1MR2A 2-channel optical add/drop multiplexing board List of Optical Amplifier Boards and Dispersion Compensation Board N1BPA One-channel power amplifier and one-channel pre-amplifier board N2BPA One-channel power amplifier and one-channel pre-amplifier board N1COA, 61COA,
62COA Case-shaped optical amplifier N1DCU Dispersion compensation board N2DCU Dispersion compensation board TN11OBU1 Optical booster amplifier board TN12OBU2 Optical booster amplifier board N1BA2 Two-channel power amplifier board N1RPC01 Forward Raman driving board (external) N1RPC02 Backward Raman driving board (external) List of power boards UPM Uninterruptible power module T1PIU Power interface board (supporting standard subracks) T1PIUB Power interface board (supporting type III subracks) Huawei osn 7500 MSTP transmission sytem Thunder link com
Aug 31, 2016 | Huawei Optix Osn 550-basic Software...
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
Nov 28, 2015 | Hitachi P50H401 50 in. Plasma HDTV
How do I determine if it a power failure or if it is a faulty SC board (TNPA5335)?
That does nost sound normal. I would take a look at the output of the power supply. Look at your electrolytic capacitors on the power supply board. Do they look like the top of them has popped up? If so you can get replacement capacitor kits from www.lcdalternatives.com
Jul 09, 2014 | Televison & Video
How to determine if it is a power failure or a faulty TNPA5335 board?
The Ysus board is possibly faulty. There is a repair kit available for it containing a few components and all semiconductors!
Jul 08, 2014 | Televison & Video
Is it a power failure or is the TNPA5335 board faulty?
As there is LED blinks, the power board is funtioning; and 5V rail is OK. The start-up voltage, that have to come from the main board doesn't. Check for the reason. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
In most cases, the main board might have to be replaced. If so, a firmware update too might be necessary.
Jul 08, 2014 | Panasonic Test Tool Part Tzsc09187
What is the difference between dispaly board and a bulletin board?
No difference. a bulletin board is a type of a display board. Display board is a generic name for all presentation boards.
Jan 24, 2013 | Office Equipment & Supplies
Panasonic TNPA5335BJ SC Board Logo
127 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
