Question about Cherokee Jeep Grand CD Changers - 10-Disc
The 10 disc unit will not eject - Cherokee Jeep Grand CD Changers - 10-Disc
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
Becker Car 10 CD Changer wont eject and hear a cycling sound
cyclying sound may be laser "trying" to read the disc, try a new store bought disc and see then , if it plays ,lasers on the way out , if u get the same sound try to obtain the service manual for the unit , most repair shops will not look at it if they dont already have a service manual . see owners manual for what discs it will paly , rw "burned " mp3 ect . its not ejecting because of possibly different issue .if error is displayed contact grand prix electronics (they made the unit) and see if they can revise solution
Nov 30, 2009 | Car Audio & Video
Ps3 not accepting/'sucking in' discs
I have the same problem. Sony told me that it is a piece of the track gets stuck on the motor shaft and then the motor cant turn to "**** in" discs or spit them out.
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
TT320 DOESN'T WORK
SIMPLE....THE TRUTECH WENT IN THE TRASH AND I BOUGHT A NEW DVD PLAYER.....END OF STORY!
Jul 07, 2008 | TruTech TT320
How to eject the disc tray when not connected to the car?
hI , to enject cd is look a piece of strong tooth pick insert to a small hole at right corner of cd changer , push and and push tooth pick until the tray comes out.
Feb 02, 2008 | Sony CDX-454RF 10-Disc CD Changer
Pioneer 10 disc changer magazine stuck
i would like to be of assistance but i need to know the which pioneer 10 disc changer it is. send me the information and i may be able to help. thanks
Nov 26, 2007 | Pioneer 6CD CHANGER
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Car Audio & Video Logo
44 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
