Question about Hotpoint WF430 Front Load Washer
Hotpoint aquarius wf430 door mechanism
Door will not open
  • 1462 Answers
SOURCE: HOTPOINT AQUARIUS 1000 DELUXE 9538
no manual way.
check machine has drained fully - if not door will not open. in this case, put drain hose down at floor level in a shallow dish to drain
otherwise
disconnect from mains.take top off. feel down front of machine where door latch is and you should be able to feel door peg thro the interlock. pry to one side with thumb nail to open (this is quite difficult)
or
break door handle off and lever door peg with a small screwdriver
Posted on Oct 16, 2008
  • 135 Answers
SOURCE: Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
  • 99 Answers
SOURCE: Door Won't Open
This is joyce
Have you tried to go to ge.com and download your documenton. your book. put in your model # and this will give you some info on why the door wont open. their is a reason.
let me know if you need any help, if you cant find out why, let me know and I will research it a little more and see if I can get you some help, but you may have to call a technician out to fix problem.
thanks
joyce
Posted on Feb 13, 2009
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
Door locked no light to say locked no washing action on hotpoint wf430
Brusheson motor will be worn. The door lock is in series with the motor so if brushes worn it interrupts the signal telling the board the door is locked. New brushes will likely be all it needs.
Oct 30, 2013 | Hotpoint WF430 Front Load Washer
Door locked light is flashing hotpoint aquarius washing machine wont start
More than likely the door mechanism is faulty and needs to be replaced
Jun 17, 2012 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint Aquarius WF430 and the drum is not turning. How do I remove the top to see if the belt has come off?
If there are no screws along the rear of the top, try inserting a thin putty knife into the front corners to release a spring lock--push straight back. The top is usually hinged at the back, so you will need something to prop it up. Hope this helps!
Aug 12, 2010 | Hotpoint Washing Machines
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Broken door handle.
Remove top cover, and reach down with a long screwdriver or similar, and actuate the door lever from inside by pushing the catch over.
Please rate my solution.
Thanks.
Apr 11, 2009 | Hotpoint Aquarius WD640 Front Load...
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf430
Had similar problem. Blocked filter and faulty pump, clean filter replaced pump approx £25. Took about 20 mins
Jul 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Door won't open
two possibilities water not fully drained - door won't open if so handle mechanism broken - check if it too free to move or sloppy
Feb 25, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WF430 Front Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
