Question about Dell Inspiron 1545 Notebook
Dell inspiron n7010 makes loud alarm sound - Dell Inspiron 1545 Notebook
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Very likely your RAM is defective. Just disconnect, clean up with a tissue paper and reinstall RAM.. If this does not solve problem take it to a local computer store to solve the problem.
Posted on May 24, 2014
RickOz
  • 145 Answers
SOURCE: no sound on my laptop dell inspiron E1505
I found many references to this issue but I am not sure which may apply to your problem. Here is a set of steps to follow from another site: (Assumes Vista and Realtek)
  • Open Vista’s Control Panel (Window | Control Panel)
  • Open the Realtek Audio Manager (not “Sound”)
  • In the navigation bar in the far right, there is a little yellow folder icon. It is just below “Device advanced settings” and above “ANALOG”. Click the folder icon.
  • Click “Disable front panel jack detection” so that a yellow check mark shows up. Hit “OK”, and close the Realtek HD Audio Manager. That should re-enable the sound.
Posted on Mar 15, 2009
  • 3940 Answers
SOURCE: Piercing, loud alarm when starting Dell Inspiron 4100 laptop
Most likely, the CPU cooling fan, as the system doesn't really start generating any heat until the windows video initializes. If you have the resource CD, run the diagnostic for the fan, see if the noise occurs during the test.
Posted on Dec 21, 2009
PCTechOnline
  • 532 Answers
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Posted on Jun 10, 2010
SOURCE: My Dell Inspiron N7010 has a splash screen that
Run a virus scan by booting into Safe Mode With Networking (which will give you internet connectivity). When it boots up, open your internet browser and download and install MalwareBytes and run a quick scan.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
Posted on May 13, 2012
Geekman
  • 32281 Answers
SOURCE: Dell Inspiron n7010 doesn't charge at all
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on May 19, 2012
Need to unlock bios in this dell inspiron n7010 can you help
Use google to find the procedure of shorting the bios pins it sounds alot harder than it actualy is
Aug 28, 2017 | Dell Computers & Internet
How do i turn off the touch pad function key on a inspiron n7010
Carl Rossetti,
You can go into the control panel and click on the touchpad properties. From there click on the device settings tab and click the disable button and apply settings.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jun 23, 2014 | Dell Inspiron N7010 Blue Intel Core...
N7010 AC adapter not detected
Hi.
make sure your charger is good, if not buy another. Now if you are good will have to replace the motherboard
Apr 04, 2014 | Dell Inspiron 17R (N7010) AC Adapter 65...
Dell inspiron N7010 wot't turn on.
call tech support and get a complete diagnostics done.
Feb 19, 2014 | Dell Inspiron N7010-JQ02DN1 17R Laptop PC...
Need hdd password for dell inspiron n7010 laptop
eracing the hard drive wont work its a seting in the bios most times its admin or password if not then go into bios to remove it
Jan 14, 2014 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
After reassembling Dell n7010 laptop it wont start at all!
Sounds like you have a problem with the motherboard. You might have zapped it with static electricity. Used motherboards are usually available for $130 delivered. Be more careful next time and avoid static electricity.
Dec 26, 2013 | Dell Inspiron 17R (N7010) AC Adapter 65...
Built in mic on Dell Inspiron N7010 will not work?
look online for the drivers most ezzy rout is to type in the name of your pc and look up drivers it will usly give you a list of all that is in your pc
Oct 27, 2012 | Dell Inspiron N7010 Laptop Core I3 2.4ghz,...
Inspiron N7010 touchpad is disabled, how to enable?
Inspiron N7010
Key to the right of the F12 key
Press the Touchpad Disable/Enable key,
(the key is located to the right of the <F12> key). Inspiron N7010
Inspiron N7010 Key to the right of the F12 key
Press the Touchpad Disable/Enable key,(the key is located to the right of the <F12> key).
Sep 23, 2011 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Notebook Logo
145 people viewed this question
Alun Cox
