Question about Zebra LI4278 Barcode Scanner
Configure my LI4278 - Zebra LI4278 Barcode Scanner
How do i adjust the wat data is entered into excel?
We recommend you contact Motorola Solutions for help.
portal motorolasolutions com
Mark
Motorola Support
Jun 12, 2014 | Zebra LI4278 Barcode Scanner
Motorola LI4278 Scanner 3of9 prefix ~ tilda
there's a program called 123scan2 where you can configure a prefix and outputs a program barcode
Feb 18, 2014 | Zebra LI4278 Barcode Scanner
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Motorola LI4278 Barcode Scanner driver
Hi i need to install drivers for my Motorola li4278.
Can you possibly help me becuase nothing happens when i plug it into my pc, so where can i download the drivers from?
Apr 04, 2013 | Zebra LI4278 Barcode Scanner
Zebra LI4278 Barcode Scanner Logo
47 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
