Question about Duplo DP21L Copier
All black copies
When i make a plate from a document i want to print the copies are all black. however when i make a plate from a print stored in memory using Help code 30 the copies are ok. i know the problem must be scanner related but the fault is intermittent. it'll work some time and then the all black copy would just pop up when a new plate is made
  • 87 Answers
It sounds like you have a fraed or partially broke wire going to your optic bar.You should inspect and also put an ohm meter on it and watch as you slide your optics back and forth.
Posted on Oct 18, 2007
How do i print copys of MX310 printer manual
Do you mean the Canon Pixma MX310 all-in-one inkjet printer? If you wish to print a copy without using a computer, first make sure that you have ink and paper loaded and that the all-in-one is on and the paper output tray is extended. Place your document face down on the glass or face up in the automatic document feeder. (Note: the scanner doesn't see the document if it is within 2 mm of some of the edges of the platen glass. If you use the ADF, remove any document currently on the glass.) Press Copy (if the unit isn't already set to copy). Check the default settings on the LCD screen and enter the number of copies desired. Press Settings to change any items and use the left/right arrows to change the number of copies, if needed. Press the Color or Black button to make the copy(ies). Color for color documents and Black for black & white documents. Press Cancel to stop copying.
The FAQ on making a copy without storing the image on a computer is here: https://support.usa.canon.com/kb/index?page=content&id=ART120681&actp=search&viewlocale=en_US&searchid=1485643876501 .
The manual is available on the product support page: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx310 . Click on the Manuals tab. The manual is in a self-extracting executable file. You'll need to run the program and then find the icon or folder where the manual is stored. (The default location is C:\Program Files (x86)\Canon/IJ Manual .)
I hope this helps. If this doesn't work, please add a comment with any error messages that you see.
Jan 28, 2017 | PRINTER Office Equipment & Supplies
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
I get a black line when scanning, ( not when printing)how do i fix it
This is commonly caused by a mark on the scanner plate. If you place your document to scan on the scanner plate (Lift the lid and place it on the glass plate) and scan or copy the document does it come out clean? If you feed the document through the Auto Document Feeder doe the line appear?
If when place on the plate it is clean but fed through the ADF there is a line, then when you lift the lid on the scanner you will see a narrow glass plate at the end (Normally the left end) of the scanner plate. Give this glass a clean and your mark will go away.
If the scan or copy is lined when using the Flatbed scanner and the ADF then the problem will be in the scanner lamp which will be probably uneconomical to fix.
Oct 09, 2014 | Brother MFC 6490CW InkJet Printer
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
I would like to know if there is a way to recall items previously copied on the Aficio 2022 copier?
NO.
The machine didn't store that info.
For all i know no machine make it.
If you had a recent model with HDD, You could stored the document in the document server (a function of the recent models with HDD) and then print the info stored in the HDD
Mar 16, 2011 | Ricoh Aficio 2022 Black and White Copier
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Duplo DP21L Copier Logo
94 people viewed this question
Top Duplo Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
