Question about Toys
Rc heli skyrover dark stealth
My rc helicopter wont fly the remote wss fine and working the heli was working the lights were on and blinking but it wont fly i throttled the remote but wont fly.also it droppd and crashed on the ground and stopped working thats probably why.
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
  • 62 Answers
SOURCE: My eagle rc helicopter wont fly
replace the rotors and it will fly
Posted on Sep 03, 2009
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 4 Answers
SOURCE: how do i fly my spin master air hog rc helicopter
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Posted on Sep 08, 2010
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
Helicopter not working
is the crystal bad in the remote. replace all batteries. move to a different area, you may be getting interference from a wireless gadget
Apr 09, 2014 | Night Hunter Xtreme Glow In The Dark RC...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
My heli always rotated at the left side.....although i push the right button it still rotated at the left side.....and it becomes hardly rotated when it start to fly.....hope u have the solution for this...
check that the fan on its tail is working fine ???
either it is rotating slow or very fast and is not being controlled by commands sent by your remote control.....
or may be the blades, either of them may be, got damaged some how and are not providing enough force to push the air and keep heli stable...
kindly check these few thing and InshaAllah your problem will be solved.. :)
best of luck...
Mar 10, 2011 | RC Helicopter With 3 Channel Remote...
My syma s107g gives a flash light in the circuit board and does not work
fully charge your heli----turn on transmitter-wait 2 seconds-turn on heli
wait for blinking green led to stop blinking-turns steady.....rev up
with a quick full throttle and back to idle--happy flying
Feb 20, 2011 | SYMA Toys industrial New Syma S107 Radio...
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
I dont know what band my helicopter is on
I'd use band A and it always works, except that it makes my ihome turn on, switch modes and radio stations, so I use band c. To connect to the heli, turn the helicopter on, wait for a red light to blink inside, then throttle up and down on your remote. Then, your all set. Just do some preflight checks and have fun!
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Jan 29, 2010 | Apache Colco Ah 64 Longbow R/C Helicopter
Toys Logo
200 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
