Question about Energizer Eveready Utility Lantern Uses 6V Lantern Battery
I bought a new battery for the Eveready Utility Lantern. How do you hook it back up?
There should be illustrated pictures as to how to rewire the battery back together. I can't figure it out. I have a brand new battery and can't figure out how to connect it to the flashlight so that it works again. :(
3 Suggested Answers
SOURCE: How do I change the
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Posted on Jan 09, 2011
usnavyretire
  • 6 Answers
SOURCE: I can't figure how to
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Posted on Jul 27, 2012
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
Nov 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How do I change the bulb of the 6V Eveready Lantern if bulb won't come out
Drop a couple of drops of WD 40 on the bulb retaining ring. Let site overnight and in the morning it will easily unscrew. Note: be sure you use only a couple of drops as you don't want to get it on the reflective lense
Sep 27, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to fix the switch on eveready lantern flashlight
The switch in the lantern is a press fit switch so you will destroy it when you remove it. Remove the lense and retainer ring. Remove the battery. With a pair of pliers, preferably channel lock water pump pliers crush the switch into small piece and discard. Trail Tech makes the exact water resistant switch model 040-ls-b and you can get it at Amazon or on eBay . The switch runs around $6.25 + $4.00 shipping
Jul 11, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Change a 220-240v/28w/3500k light bulb
The question does not make sense since it doesn't pertain to the 6 volt dc flashlight
Jul 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
Jun 14, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to connect a spring pole 6v battery
Inside the case of the light, there will be 1 wire with a tapered notched connector. Take the connector with the low end of the taper and push it into the negative (-) spring (in between the coils ) of the battery. The spring will wedge the connector it one of the notches and will hold it securely. Reattach the lense carefully seating the end of the bulb onto the positive (+) spring of the battery.
May 25, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Replacing a 6 volt battery
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
Jan 09, 2013 | Energizer Eveready Utility Lantern Uses 6V...
I have bought a new 6volt battery for my dolphin but can't work out how to replace it.
The bezel (the circular portion on the front of the flashlight that holds the bulb and lens) will unscrew. The old battery should slide right out.
Hope this helps.
Apr 07, 2011 | Energizer Eveready Utility Lantern Uses 6V...
How do I change the bulb of the 6V Eveready Lantern?
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
Energizer Eveready Utility Lantern Uses 6V Lantern Battery Logo
64 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
weirdtop
NicK Hale
Level 1 Expert
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
