Question about Toshiba Satellite L305D-S5935 15.4-Inch Laptop
Get notice saying MagCore.dll for 64 bit is not working. Toshiba Satellite L305-S5939 laptop
My laptop does'nt work in normal mode but its working on safemode.thus anybody can help me how to enable a sound on safemode? thanks in advance for those who have idea
"Safe mode" is really a diagnostic mode. "doesn't work" means what? Depending on what the problem is, we may be able to fix it. Please describe exactly what you mean by "doesn't work". Screen blank? Keyboard not responsive?
You can try setting the screen resolution to 640 by 480 while in safe mode, and see if that gets you someplace when you go into normal mode.
Oct 13, 2014 | Toshiba Satellite L305-S5939...
Number lock not working
go to control panel open device manager click the little arrow next to the keyboard. right click each of the keyboards listed & uninstall them (do not delete the drivers if asked). Then restart your computer & those drivers will re install. If that does'nt fix it, you will have to replace the keyboard . search how to replace that keyboard & it will show you.
go here:
Toshiba Satellite L305 Black Glossy Video Installation Guide
Sep 16, 2014 | Toshiba Satellite Pro C850-10N 15.6-Inch...
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Built-in wireless LAN on Toshiba Satellite L305-S5875, is there a Realtek driver available fo rthe 32-bit system?
Yes, the actual driver is for 32/64 bit systems. you can get it directly from the Toshiba website.
  • go to the main page of Toshiba ; Toshiba.com
  • click on Consumer Product
  • then click on Tech.Toshiba.com option (Last on the right)
  • then click on Download and choose the model you have
  • then FILTER to WIFI and you will see the Realtek driver for the Wireless LAN compatible with 32/64bit system.\
Thank you for choosing FIXYA.com for finding the solution.
Sep 13, 2010 | Toshiba Satellite L305-S5875 Notebook
Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
Nov 25, 2009 | Toshiba Satellite L305-S5908 Notebook
Juatin: toshiba satellite L305 has some problem
It seems this is a windows problem. Try reinstalling windows, or repair it within the boot cd
Jul 29, 2009 | Toshiba Satellite L305-S5907 Laptop
Toshiba Satellite L305D-S5935 15.4-Inch Laptop  Logo
253 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
