Question about Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM
Install headphone batteries - Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM
Do I need batteries for this device? If so, what kind, and how do I install them?
You do not need batteries.
Batteries are required in wireless headphones, that do not have a cable with plug.
May 04, 2014 | SOL Republic Master Tracks MFI...
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
I have an Arkon HP1180 Cordless Headphones with no instructions.
hello know the green light stays on only goes of when you take head phones of unit
Mar 22, 2009 | Unwired Audio Players & Recorders
Problem Installing batteries in cordless headphones
Having removed the soft pad, there is a flat sheet of plastic attatched that goes round the speaker (sort of doughnut shaped, with a hole in the middle where the speaker sticks out). Carefully pull this perpendicular to the speaker, and it'll come off (the four rectangles you can see on the surface of the sheet are pegs that click into the main body to hold it in place). Under there will be one battery compartment. Repeat both sides, and you're done. This stumped me for ages!
Jan 01, 2009 | Audio Players & Recorders
Difficult to open battery pocket in Maxell's HP/NC-IV head phones
Put both thumbs in the indentations on the LEFT headphone cup and pull down.  Hard.
The silver "Maxell" oval (along with the lower third of the headphone cup cover) will come off, revealing the two AAA batteries.
Dec 18, 2008 | Maxell HP/NC-III Consumer Headphones
Twist the velour padding inside slightly and pull it away from the headphone. It'll come off - the batteries are underneath.
Apr 28, 2008 | Sennheiser HDR 120 Consumer Headphones
Maxell NC-II noise reduction headphones.
Look closely at the battery icons under the batteries.The installation of the batteries in these headphones is different than most electronic devices the batteries sit side by side in the same direction both + ends are on top and both - ends are on the bottom
Jan 06, 2008 | Maxell HP/NC-III Consumer Headphones
Meridian Point 6 in 1 Wireless Headphones For TV Stereo PC MP3 CD DVD Player FM Logo
Top Meridian Point Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Meridian Point Audio Player and Recorder Expert? Answer questions, earn points and help others
