Question about Toshiba TDP-ET10 DLP Projector
Projector will not turn on from standby
Projector will not go on from standby
Hi, did you ever get an answer to your question? I have an ET20 which, after several months of non-use, has now stopped working. The standby light is on, it makes a startup 'noise' but then does nothing. None of the other buttons are illuminated. Is this similar to your problem?
Posted on Jul 18, 2014
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
When I turn the projector, i hear clicking from my AV receiver, the MITSUBUSHI screen then blue screen shows up on the wall, but then it says no signal: then the projector goes to standby without me doing...
The problem is most likely a warped plastic housing around the color wheel. When the wheel is forced to stop, the projector will go to standby and the lights indicate a problem.
Apr 23, 2017 | Mitsubishi HC5500 LCD Projector
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
AFTER REPLACEMENT OF TOSHIBA PROJECTOR TLP791 LAMP IS NOT WORKING . PLEASE SUGGEST THE LAP TIMER RESET METHOD. R K MISHRA SATNA MP INDIA
To reset the lamp hour of Toshiba TLP791, do the following.
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord.
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
The lamp reset procedure is over.
ok
Jul 16, 2011 | Toshiba TLP 791 Multimedia Projector
How can i reset the lamp timer ???? Typ of beamer: Sony VPL-FX51 E-Mail:francois.humbert-prince@vtg.admin.ch
Connect with power cord and turn the projector to the standby mode.
Press the following keys on the control panel in the following order for less than in five seconds each: RESET, LEFT arrow key and RIGHT arrow key and then ENTER.(showing in the picture below)
(NOTE projector must be in standby mode and keys pressed less than five seconds)
now press power/standby key to ON the projector and check lamp hoursgood_help_1.png
Jan 31, 2011 | Sony VPL-FX51 Multimedia Projector
I want to rest the Lamp timer of Toshiba Projector TDP-TW95 after replacement of New Lamp
hi
reset ur lamp timer through the following procedure
p { margin-bottom: 0.21cm; }
ok
Jan 06, 2011 | Toshiba TDP-TW95 DLP Projector
How do i reset lamp hours for a toshiba TLP-T721
I have not actually tried this but on a different post, here's the wild solution:
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
Sep 02, 2010 | Toshiba TLP T721 Multimedia Projector
HOW DO YOU PUT THE SYSTEM IN STAND BY
Turn Power Off by pressing power button on projector, it is now in standby.
If projector is plugged in but not in power On mode or not showing picture, it calls standby.
Aug 27, 2010 | Sony VPL PX40 Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Hi Warson
If the Projector is switched on hold down the Enter button on the Projector itself for about 5 seconds - a on-screen display will appear that reads : " Keylock off "
This can also be done while the Projector is in standby mode by holding down the Enter & Standby/On buttons simultaneously for 5 seconds.
This should do the trick.
Good luck and thanks for using Fixya !
Apr 29, 2008 | Sharp XR-10X Multimedia Projector
Toshiba TDP-ET10 DLP Projector Logo
104 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
