Question about Kirby G4 Bagged Upright Vacuum
Kirby G 4 Problem
When I turn on the hoover it sounds like it is sucking up bits of stone for a moment then the noise stops and it sound like it should. The brush part is spinning but there is a definate loss of suction.
Any ideas what the problem may be, we have replaced the brush and the belt.
  • 357 Answers
Re: Kirby G 4 Problem
Please click this link to view my troubleshooting guide....
Hope it helps!! :0)
Posted on Oct 23, 2007
0 characters
3 Points
Hi. My dyson dc14 wand works great then all of a sudden if something too big or even just the carpet it makes a sucking noise & the purple round bit in the actual Hoover makes a funny noise & then...
Sounds like a blockage. I have a DC14 and I have never had this problem. You can easily remove the wand from the flexible hose and the flexible hose from the machine to check for a blockage. Don't allow paper or larger items to go into the machine, especially the wand, pick it up by hand first. Find the online manual here:
May 03, 2013 | Vacuums
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
Motor bogged down, smelled rubber, brushes stopped turning
This repair would require motor replacement, based upon your explanation.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
G5 intermittently or not at all pulling up dirt
Turns out that little light is a BELT indicator. Even though the belt wasn't broken it had stretched and needed to be replaced. So a $2 part and my baby is working as well as ever!!
Jan 17, 2009 | Kirby G5 Bagged Upright Vacuum
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair.
Oct 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Kirby sentria
Hi There, The machine does not actually suck the suds up. Basically the machine lays the foam down which then crystalises and absorbs the dirt in the process. Once this has had around - 4-5 hours to dry then you vacuum up as normal taking the crystalised dirt away. You should really use the Genuine Kirby product as it's very good but you can also you any other DRY FOAM shampoo. Hope this helps Chris
Sep 22, 2007 | Vacuums
Carpet shampooer
hi, I used to sell these, and can tell you that they are not designed to suck up the water. They are made to put a limited amount down and then the brushroll scrubs it. Then it drys and ideally you would vacuum up the dried residue that is left. I own one myself, and admittedly the shampooer is not as good as the ones that steam clean and suck it up, but it does ok. The longer you sit in one area, the more water is going to go down, so keep it moving. And remember that it is going mostly at the middle of the unit, so it's good to overlap a bit. If you have troubled stains, I can suggest spraying some type of cleaner on it and going over it with the brushroll--like windex. My buddy also used to sell them, and that worked for him.
Sep 02, 2007 | Kirby Heritage II Vacuum
Kirby G4 Bagged Upright Vacuum Logo
124 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
