Question about LeapFrog LeapReader Reading and Writing System - Pink
Its not working
Leapreader pen isn't working it doesn't respond to the book it doesn't respond when I press the buttons. ive charged it til it was fully charged battery icon showed fully charged & green light was on I unplugged it from laptop & plugged it bck in the battery icon showed half charged even though I had fully charged it. when I try to turn it on while it is connected to laptop it keeps turning itself off. audio companion wont download it doesn't do anything when I click on download but when I look on my products it shows that its on the leapreader.
5 Suggested Answers
SOURCE: Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
Posted on Jan 02, 2009
SOURCE: the fly pen is not turning on
it just has to charge. whn i turns d its charging. leave it for 15min andn take it out and turn it on. if it doesnt tn on contact an expertfrom the place u got it.
Posted on Jan 15, 2009
SOURCE: leap frog tag pen won't work any longer.
I found that after replacing the batteries, the power button on the reader did not work. I did however have luck after I connected the Reader/Pen to the laptop, updated the s/w on the reader and updated the s/w on the laptop. Then the reader was able to interact with one of the books just fine.
Posted on Sep 17, 2012
dpoint
SOURCE: The Save to Tag button on the leapfrog connact application does not do anything and so none of the audio will download from the library to the actual tag device
I've changed the battery. I've checked the country. I've installed everything on another computer. I've uninstalled and reinstalled. And still, the "save to tag" button does nothing. Nothing syncs. Any other solutions? There are audio files on the Tag, but I can't remove any and I can't add any.
Posted on Dec 28, 2012
How to add a leapreader book to a leapreader
you will need to download the LeapReader software from the LeapFrog web site
www.leapfrog.com
Install following the wizard
once installed on the righ there will be a link to download and sync the new software for your books
i hope that this helps?
Regards
May 06, 2014 | Toys
Leapreader won't turn off
Try pressing the on/off button to turn it off. I had a same problem. I depressed the on/off button for ~6 second or so and the device turned off. When I turned on again, the LeapReader no longer had a white light and was recognized by my computer.
Feb 01, 2014 | LeapFrog Toys
SYSTEM DOESN'T RECOGNIZE CONTROLS HOW DO I FIX
I'm guessing the issue is that the PS3 isn't responding to your controller input.
Ensure that the PS3 controller is actually on. You can turn on the controller by pressing the Playstation button in the center of the controller. There will be a red light on top of the controller indicating that it is on.
If no light shows up, it's possible that the controller simply has dead batteries. Grab your controller charge cable (should have been included with controller, looks like this) and connect the controller to the PS3 while the console is on. Give it a few minutes, then press the center Playstation button again and see if it responds.
It's also possible that the controller just isn't synced to your PS3. Again, grab the charge cable and connect it to your PS3 while it's on. Then press the Playstation button while the controller is connected. It should sync it to the PS3.
If none of that is working for you, there may be an issue with the controller itself. The easiest fix it to reset the controller. There should be a tiny button in a hole on the back of the controller. Just press it (you'll need a paperclip or something to do it) and the controller will reset. I believe you'll have to re-sync the controller (using the cable again).
You should also try syncing other controllers to your PS3 to make sure that the issue isn't with the PS3 itself (which would be awful; I've never heard a PS3 breaking like that but I suppose there is always a first). If other controllers work then either your controller's battery is dead or the controller is actually broken. I don't think Sony repairs/replaces controllers so you may have to buy a new one.
It may be worthwhile to checkout their support page first, to see if anything helps before shelling out 50$ for a controller:
Sony Support
Sony Repair
Amazon - PS3 Controllers (I recommend Silver; it's ****).
Hope it all works out!
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
What do I do to input the code?
on rca controls there is allways a setup button press it for the light to flash several times them pres the device you want to controll then press the power button several times un til the device turns off then just press enter if that does not work try setup wait for it to flassh then press device you want then channel up til it responds then enter
Oct 26, 2009 | RCA RCR-4258 Remote Control
The pen won't work on my daughter's leapster
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
Leapster doesn,t respond when the pen touch screen
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Sep 29, 2008 | LeapFrog Leapster Electronic Book:...
Power button doesn't respond
Is not the power swich, it could be lithium batt.
you need to replace.
and you say that about 5-10 minutes of pressing, with the back of a writing pen it work.
is cause the lit batt is charge all ready. But not enough.
Feb 07, 2008 | HP Pavilion dv6000z Notebook
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
LeapFrog LeapReader Reading and Writing System - Pink Logo
183 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
GI Consulting
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
