Question about Dell PD01S (PD01S) External Floppy Drive
Dell pd01s not reading or identifing discs
It runs fine. I can hear it running, but it doesn't really read the disc it starts and stops starts and stops alot and then just quits. tried other discs and I have cleaned the thing inside and out.
antiochpc
  • 1314 Answers
SOURCE: "Disc read error" Dell Inspiron 1501
This means your hard drive is bad. You need to replace the hard drive and then the operating system.
Thanks and please take a moment to rate as fixya.
Posted on Nov 26, 2008
  • 31 Answers
SOURCE: error code c0000218 for a dell inspiron..
your best bet is to get a convertor connector for the laptop drive to full size IDE drive and put it in a desktop as a 2nd drive to format the laptop drive using the desktop, put it back in the laptop and do a clean install/restore.
Posted on Feb 14, 2009
  • 262 Answers
SOURCE: My Dell Latitude D531 has been turning itself off
sounds like cpu is over heating ....... need a new cpu lala linda
Posted on Jun 15, 2009
md_ehsan_1
  • 255 Answers
SOURCE: Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Posted on Jun 28, 2009
  • 3940 Answers
SOURCE: I have a Dell inspiron 531s desktop computer w/ a disc read error
Disc Read error indicated a failing hard drive. Replace the drive will be the fix, then reinstall Windows
Posted on Oct 28, 2009
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Problem reading dvd disc
hi there
that only means that it has difficulty reading the disc that you inserted.
have your disc cleaned and try to check if it will do the same thing with other discs.
hope this helps
Jan 29, 2008 | Panasonic CT-30WX54 30" TV
Loose boobin winding
You need to ensure that the thread is going from the thread spool at the back of the machine, through the eyelet, then around the silver tension disc on top of the machine, then to the bobbin when you are winding it. Also, pull the thread tail up through the hole in your bobbin to start and hold the tail so the thread starts to fill smoothly and doesn't loosen.
I've marked the disc in red on this image
Please read my Tip on bobbin winding; its really important to get a good wind and you can add more tension yourself by applying gentle pressure to your thread spool on the back pin as you wind off it.
Link is http://www.fixya.com/support/r10598580-winding_bobbin_correctly
The stopping when full is possibly because your bobbin is winding unevenly but I never run it until it stops itself anyway, and do the winding at 3/4 speed, not flat out. You want a really smoothly tensioned even wind onto the bobbin so your thread comes off the bobbin when stitching with even tension, not stretched, then loose.
Hope this helps you with your problem.
Dec 14, 2011 | Elna Quilter's Dream 6003Q
Dvd problems
The issue is the motor will need to be replaced, And why i always suggest to cosumers not to buy all in ones for this purpose. The labor to fixy this is over $100 bucks alone and the part you need to replace the entire dvd unit in this.
1. check your warranty
2. bring it to a shop to have the unit fixed
Thanks and please do leave positive ratings and feedback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 13, 2010 | Haier HLTDC19 TV
Pioneer CLD-95 only spins laserdiscs when it feels like it
It sounds like the read head assembly is not resetting back to the starting point so it can start off reading the "A" side of the next disc. Probably turning it off and then on resets it back to the start of the "A" side. You might try flipping the disc manually to the "B" side, let it go and then try another disc to see if it works.
Mar 30, 2010 | Televison & Video
Dell PC unable to read blank discs
There is a easy solution! Buy a new DVD burner...
I went through 2 DVD burners in one year (I bought a really cheap "mad dog" DVD burner...never again to say the least). I saw a "insert disc", even though there was already a disc in the burner, and thought "I'm not paying for a new burner, I'll fix this one...". I eventually got it to work again, but all that I got was corrupt disc after corrupt disc.
I'll bet that it still reads CD's fine doesn't it? Yeah? Well then, trust me, buy a new one. It'll save you time, money (you won't waste all those DVD/CD's), headaches, moments of depression, anxiety, frustration, and your sanity.
Except no substitutes of a solution. Don't go through what I did...
I also suggest ccleaner (freeware) from filehippo.com to clean out the system and not only run the "Analyze/Clean", but also verify "Tools/Startup" and uncheck ANY program that you are unsure of.
Dec 14, 2009 | Computers & Internet
My xbox has been put together from two xbox's(one of which had broken and the other that was fine but was lacking hard drive and other acessories.)So, I put both of them together and it works fine. Except...
This forum might be able to help you:http://www.xbox360forum.com/forum/xbox-360-console/72481-replacing-360-cd-drive.html You can also google on how to flash your drive.
Nov 30, 2009 | Microsoft Xbox 360 Console
Disc Read error on original early PS2--ticking noise
Hi you will probably get constant disk errors because it is not the best console you can get. The older versions are now stopped being prossesed. My best bet is to get some rubbing alcohol.The spray doesnt really make an effect but will also make an effect.Im not sure what the effect is but your bets bet is to get rubbing alcohol.
If you have any further questions please ask me.
Thank you.
Mar 01, 2009 | Sony PlayStation 2 (PS2) Console
Reads a new disc,but after a few uses will not read.
First try cleaning the heads with a kit that may be obtained at many discount stores. If that doesn;t work, It really sound like a drive head alignment problem. Not a service preformed w/o equiptment.
Jan 01, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Dell PD01S (PD01S) External Floppy Drive Logo
Alun Cox
