Question about Canon Cameras
Canon s51s pictures are grainy and dark
I have tried every setting imaginable. Even outdoor pictures in bright light are dark and grainy. THis camera used to take amazing pictures.
markevans
  • 148 Answers
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Posted on Dec 24, 2007
SOURCE: Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Posted on Feb 21, 2009
zohail
  • 1223 Answers
SOURCE: Canon A460 : Image taken are very bright!!!
no my friend it is not ur sis fault !
actually it is a known CCD Problem thousands are facing these days see the link
http://www.imaging-resource.com/badccds.html
ur camera will be completely OFF in few days after full Failure !
But dont worry u can get it repaired free of charge postage paid from CANON directly even if u are out of warranty and not on list of service advisory just call them bcoz it is a manufac fault see the link call canon in ur region and go rate me FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Posted on Apr 11, 2009
t00nz
  • 4738 Answers
SOURCE: pink tint in pictures taken using canon s500
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 10, 2009
  • 73 Answers
SOURCE: I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
Posted on Jul 27, 2009
My camera was dropped and now the aperture is messed up, giving me really dark and grainy pictures in bright surroundings, even set as low as 25.
i suggest you take the camera to a digital Canon repair shop and ask them for a repair quote. They may charge for a quote unless you go ahead with the repair, then you can decide whether to get a new body or get it repaired.
Sep 27, 2012 | Canon EOS Rebel XSi Digital Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
All of the pictures are grainy and very dark- not usable camera at all- less than 2 years old I have re formatted the SD card, changed the batteries, and reset the camera to default settings
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Feb 24, 2011 | Canon PowerShot SX110 IS Digital Camera
My canon powershot s3 IS is taking really dark pictures. The only decent pictures I can take with it are outside in sunlight. Pics indoors come out dark and grainy. I flip up the flash, but most of the...
This is not an answer. The S3 normally does not produce dark pictures, and I have seen this issue before. It has to do with a setting somewhere on that camera that needs to be adjusted. I wish I knew what that setting was/is as my wife's camera has recently started doing this ...
Jan 04, 2011 | Canon PowerShot S3 IS Digital Camera
I own a canon PowerShot S51S. When I open the camera to take a picture , it is blurred. But when I download to my pc or look them after in the camera it's O.K. Any help would be appreciate.. Lise
I'm not totally sure of your question or concern but let me attempt to show some light on what it is I think you are asking. The Canon PowerShot S51S is a huge step up from a pocket point and shooter, this is a very powerful camera with features that would make some Pro camera whimper. So to the problem I think you are having. The camera is fitted with an optical viewfinder but the image you are seeing isn't "Through the lens" in fact it's a digital image of what the camera sees and therefore will not appear clear to your eye. The image will look a little grainy and slightly out of focus. If the in focus indicator is showing your image is focused then take the picture as long as the focus indicator light is on then the picture will be in focus. The problem you are experiencing is compounded if you wear glasses. This is one place where you need technology to rule. I know what you are feeling believe me because I still have problems with a digital viewfinders. Right now I use seven different cameras one of them has the digital viewfinder and it just make me stop and think then rely on the in focus indicator. Hope this was a help but as long as the camera is functioning properly you have no concerns. By the way you have chosen a great camera for creative photography. Happy Holidays from Robert in Canada
Dec 24, 2010 | Canon PowerShot S51S Digital Camera
Jan 29, 2009 | Polaroid i1035 Digital Camera
Grainy pictures
Try going into the cameras menu setting and see if you can change the picture quality settings to the best setting! (the more mega pixals the better the picture when you blow it up or crop it!
If you cant figure out the menu come back and see us we will be glad to help!
Please rate my response to your question!
Thank You!
Jan 08, 2009 | Canon PowerShot S51S Digital Camera
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Pictures are too bright when shooting outdoors in sunlight
Have you tried changing your settings manually to outdoor? Or adjusted the aperture? You can usually find the aperture settings under the menu button. If not, try adjusting to outdoor conditions and disabling flash. And also, lower your white balance a good bit.
May 01, 2007 | Canon PowerShot SD600 Digital Camera
Cameras Logo
12 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
