Tv will not come on, the standby light is flickering as if trying to come on
We have had our tv for about 18 months and for about a week it has been making funny noises and a week or so after that the tv was struggling to turn its self on, like taking its time to show pictures on the screen, and we new there was a problem as the standby light was flickering. I came down stairs this morning to turn the tv on and it has not come on at all i am still waiting , it has been 2 hours now. can you help please?
  • 6 Answers
SOURCE: Flickering blue picture
I finally got around to dismantling the TV. This is no mean task. The chassis is tethered to the rest of the set my over a dozen wiring harnesses and a few of these cannot be disconnected near the chassis but instead require removing the “right support” near the air duct and taking the shield off the lamp ballast. Once the chassis assembly is out, it is a further significant task to disassemble it to get at the various PWBs (POWER, FMT and DM) having the suspect caps. I’m sure reassembling everything will be a fun job!
I have not yet had a chance to fix and reassemble but I wanted to post this no as I’m not sure when I will get around to it.
I did find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Posted on Feb 16, 2008
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
video-tek
  • 150 Answers
SOURCE: Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Posted on Feb 10, 2009
Axle80
  • 73 Answers
SOURCE: samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Posted on Jun 06, 2009
  • 11800 Answers
SOURCE: Brand new WD-65737 2 weeks old. Works great. I
There's something wrong in the power source of the tv , very bad sign on a tv just 2 weeks old. Just take it back, not worth the hassle.
Posted on Jun 16, 2010
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Model LG 42 PX3RVA ZC Hi I have a lg plasma, bought in 2005 new. I know it's old.. But was working well until a couple of weeks ago. Picture would flicker initially when turned on, then as tv "warmed...
With no stand by light, you are not getting power.Unplug TV and check fuse on power supply. You will need a meter to look for shorted components and possibly leaky/bulged capacitors that are killing your power supply. flickering could be part of the bad power supply or possibly a problem with YSustain area of your TV
Feb 15, 2014 | LG Televison & Video
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Tv went black and no sound standby light falsh twice and paused and flashed twice again
This indicates a short happened somewhere in the set, causing the set to go into "safe mode" where it won't let itself turn on. Oftentimes it's the convergence board. Depending on what that will cost you, you may want to just replace the set.
Mar 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony blinking standby light
This is Sony's way of telling you that there is a short in you set.Probably the horizontal deflection circuit.(Horizontal output transistor shorted??). Also any other short. You need to take it to a techincian and have it checked out. It would be wise to get an estimate! Stargazer
Feb 05, 2007 | Sony KV-32CS70 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
