Trying to connect my Asus K35sv to my Toshiba 32av605pg
I can't seem to get the image to fit the screen properly with any of the resolutions. I've connected the laptop and the tv with an hdmi cable.
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
  • 96 Answers
SOURCE: No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Posted on Feb 10, 2009
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
hawk127311
  • 350 Answers
SOURCE: I have a dynex TV I am trying to connect to my
Make sure that you set your laptop to external display by using the proper F key, located on top of the keyboard. It looks as though there are two computer monitors on it. My Gateway is F4 for example. Press the function key and the proper F key simultaneously. There are a few choices, so you may have to push it more than once. I hope this helps and good luck!
Please remember to vote 937f12f.jpg Thanks.
Posted on Oct 31, 2009
On my nb305 toshiba laptop with windows 7 ultimate, the screen resolution is too large to all fit on the screen. Ive tried all the avalable resolutions and also re installed the drivers
It seem your screen size has neem set to 640 X 280 or there abouts you should be able to right click screen got to Screen resolution and change it from there if not check the toshiba site for correct drivers
Jan 09, 2017 | Toshiba Computers & Internet
Toshiba TV - no full screen
You need to go to the control panel in your computer and change the display resolution. The two resolutions are not matched is the only problem here. Find out what the native resolution is of your tv and match it in your computer.
Jan 27, 2014 | Toshiba Televison & Video
Monitor image became offset to the right. How to fix this?
Have you tried telling the computer that you want a single display and not dual?
Dec 19, 2013 | ASUS VW192S Monitor
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
Poor quality when connecting TOSHIBA laptop to LG LCD screen
It seems the LCD screen has a higher resolution the laptop Video Card cannot supply such image quality.
Aug 29, 2012 | Toshiba Computers & Internet
I am unable to change aspect control on my ASUS ML238 monitor, using monitor controls as they are not highligted on the menu. HDMI is selected however, but the monitor image does not cover the whole...
The resolution controls are on the device that is plugged in on the HDMI cable attached to your ASUS ML238. In other words, if it is a PC or laptop, you will need to go to the resolution settings to find the fitting screen resolution for your monitor.
See the link below for more detailed instructions.
How to Change Screen Resolution in Windows 10
Feb 20, 2018 | Computers & Internet
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
Asus eee pc resolution vs. screen
Your computer does not support any resolution greater than 1024X600, anything other than that you will have issues.....
Display Screen Size: 10.0" Display Type: WSVGA Max. Resolution: 1024x600
Oct 12, 2009 | ASUS Eee PC 1000HA Netbook
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
